I'm completely stuck on the following problem:
Consider an example of unidirectional non-linear wave motion:
$u_t + uu_x = 0$, with $u(x, 0) = f(x)$.
i) Show that the characteristic variable $s$ is defined by the implicit equation $x = f(s)t + s$ and that the solution can also be expressed implicitly in the form $u(x, t) = f(x − tu)$.
ii) Using implicit differentiation, show that $u_x = \dfrac{f′′(x − tu)}{1 + t f''(x - tu)}$ and hence determine a condition when the solution will break down.
iii) With the example $f(x) = −x$,
a) Show that the solution breaks down at $t = 1$
b) Sketch the characteristic curves for this case and explain your sketch in relation to part (a)
c) Sketch the solution as a function of time between $0 ≤ t ≤ 1$.
I've spent hours on it, but I can't seem to make any progress. And, unfortunately, the book has no solutions for me to read and learn from.
I would greatly appreciate it if people could please take the time to demonstrate how this is solved, with explanations that justify their work so that I may learn what It is I'm not understanding. I will study any answers and reference it with my textbook, so that I can figure out what it is that I'm not understanding.
