I can't understand this:
Given a matrix T =$\small \{T_{ij}\} \in \mathbb M_{mn}$,define a transformation $\small T:\mathbb R^n \rightarrow \mathbb R^m$ as follows:
If $~~\small T(x_1,\ldots \ldots,x_n)=(y_1,\ldots \ldots ,y_m)$ , then $~\small y_i=\sum_{j=1}^{n}T_{ij}~x_j~~$ for all $\small i=1,.....,m$
I can't differentiate between a linear mapping and the matrix of transformation.Aren't they representing the same thing.Please help me understanding the difference between them...
hardmath
  • 37,715
spectraa
  • 1,835
5 Answers5
14
The matrix T represents the linear transformation $T$ subject to the choice of an ordered basis for each the domain and the codomain. Change the bases and you induce a corresponding change in how the linear transformation is represented.
But the linear transformation $T:\mathbb{R}^n \to \mathbb{R}^m$ is the same regardless of what basis you have in mind.
Often we want to pick a basis (or bases) so that the matrix T will be especially nice, say a diagonal or block diagonal form, or some other sparse representation (lots of zero entries).
But again, changing basis will affect only the matrix representation, not the linear transformation itself.
The case where $n=m$ is a little special in that ordinarily we prefer to use the same basis for the domain ("input") and the codomain ("output"). It is not mandatory to do so, but it imposes an extra burden on memory to keep track of whether $\mathbb{R}^n$ is being used for the input or the output, and think in terms of the appropriate coordinate system for the purpose.
To simplify matters we will give an example of representing a linear transformation $T:\mathbb{R}^2 \to \mathbb{R}^2$ that uses the same basis for both. First consider the standard ordered basis for $\mathbb{R}^2$:
$$ \mathscr{E}_2 = [(1,0),(0,1)] $$
Note that I'm using square brackets, rather than a pair of curly brackets, to emphasize that we chose an ordering of the basis vectors. Curly brackets would mean a set, and the set does not entail any special order of its elements.
Consider now a linear transformation $T:\mathbb{R}^2 \to \mathbb{R}^2$ defined by swapping the $x,y$ coordinates:
$$ T(x,y) = (y,x) $$
With respect to the standard basis we have a matrix $M$ such that multiplication by $M$ converts the standard coordinates of input vector $(x,y)$ as a column vector into standard coordinates of output vector $T(x,y) = (y,x)$ as a column vector:
$$ \begin{bmatrix} 0 & 1 \\ 1 & 0 \end{bmatrix} \begin{bmatrix} x \\ y \end{bmatrix} = \begin{bmatrix} y \\ x \end{bmatrix} $$
It's important to understand how the column vectors represent an input/output vector with respect to our chosen basis. Every vector can be represented uniquely as a linear combination of basis vectors, so in the case of the standard basis we have:
$$ (x,y) = x\cdot (1,0) + y\cdot (0,1) $$
But for the sake of making matrix multiplication work, we take those scalar multipliers and create a column vector with them as entries corresponding to the order of the respective basis vectors. In standard coordinates we represent $(x,y)$ as $\begin{bmatrix} x \\ y \end{bmatrix}$ and $(y,x)$ as $\begin{bmatrix} y \\ x \end{bmatrix}$. Thus the multiplication by $M$ shown above converts the standard coordinates for $(x,y)$ to the standard coordinates for $(y,x)$.
Now let's try this with a "nonstandard" basis. Sometimes a better basis for representing a transformation may be as simple as just changing the order of the vectors in an existing basis, but we are going to do a more complicated example just to contrast steps that are easy from steps that are harder.
Choose nonstandard basis $\mathscr{B} = [(1,2),(3,4)]$. To verify this is a basis for $\mathbb{R}^2$, we only need to point out that the two vectors are linearly independent (neither is a multiple of the other, since there are only these two), and since the count (two vectors) matches the dimension (two), it must be a basis.
What we want is to find a $2\times 2$ matrix T that represents $T$ with respect to this nonstandard basis. That is, multiplying the column vector of nonstandard coordinates for an input $(x,y)$ should give us the column vector of nonstandard coordinates for its output $T(x,y)=(y,x)$.
The recipe I recommend is to make use of what we already know, the matrix $M$ which represents $T$ in standard coordinates. Specifically:
(1) Find a matrix $B$ whose multiplication converts columns of nonstandard coordinates into columns of standard coordinates.
(2) Find a matrix whose multiplication converts columns of standard coordinates into columns of nonstandard coordinates, name the inverse $B^{-1}$ of the matrix found above.
Then T = $B^{-1} M B$, because multiplying by T accomplishes the properly sequenced operations to go from nonstandard coordinates of an input to nonstandard coordinates of its output.
Framing things in this way makes the exercise very tractable, because matrix $B$ turns out to be something we can write down "by inspection". Suppose that a vector $(x,y)$ has nonstandard coordinates $\begin{bmatrix} u \\ v \end{bmatrix}$. This simply means:
$$ (x,y) = u\cdot (1,2) + v\cdot (3,4) $$
If we write down what this means in standard coordinates:
$$ \begin{bmatrix} x \\ y \end{bmatrix} = u\cdot \begin{bmatrix} 1 \\ 2 \end{bmatrix} + v\cdot \begin{bmatrix} 3 \\ 4 \end{bmatrix} $$
it becomes evident that $B = \begin{bmatrix} 1 & 3 \\ 2 & 4 \end{bmatrix}$, with the columns of $B$ formed by standard coordinates of our nonstandard basis vectors:
$$ B \begin{bmatrix} u \\ v \end{bmatrix} = \begin{bmatrix} 1u+3v \\ 2u+4v \end{bmatrix} $$
To carry out our construction of T as $B^{-1} M B$, we will need to invert $B$, and this is certainly more effort than it took right down $B$ "by inspection". I leave it to the Reader to verify that applying the usual trick for $2\times 2$ matrices:
$$ B^{-1} = \frac{-1}{2} \begin{bmatrix} 4 & -3 \\ -2 & 1 \end{bmatrix} $$
Finally we get (if I've not made a mistake) that T is:
$$ \frac{-1}{2} \begin{bmatrix} 4 & -3 \\ -2 & 1 \end{bmatrix} \begin{bmatrix} 0 & 1 \\ 1 & 0 \end{bmatrix} \begin{bmatrix} 1 & 3 \\ 2 & 4 \end{bmatrix} = \begin{bmatrix} -\frac52 & -\frac72 \\ \frac32 & \frac52 \end{bmatrix} $$
As a quick check, consider a nonstandard basis vector $(1,2)$, whose nonstandard coordinates are $\begin{bmatrix} 1 \\ 0 \end{bmatrix}$. Multiplying by T gives the first column of T, namely $\begin{bmatrix} -\frac52 \\ \frac32 \end{bmatrix}$, which should be the nonstandard coordinates of $T(1,2) = (2,1)$. Sure enough:
$$ (2,1) = -\frac52\cdot (1,2) + \frac32\cdot (3,4) $$
hardmath
  • 37,715
  • thanks for the answer.please can you just help me being more clear about " Change the bases and you induce a corresponding change in how the linear transformation is represented." with the help of an example.. – spectraa Sep 23 '14 at 13:30
    Yes, I'll be glad to do that. Sometimes the representation stays the same when you change basis, e.g. the identity transformation is always and only represented by the identity matrix. But this is a special case. – hardmath Sep 23 '14 at 13:36
  • thanks the explanation was really helpful.... – spectraa Sep 23 '14 at 16:16
    Here's an exercise to help cement the steps in your understanding. Using the same linear transformation $T:\mathbb{R}^2 \to \mathbb{R}^2$, find a basis $\mathscr{B}'$ that give a diagonal matrix representation. Hint: eigenvectors. – hardmath Sep 23 '14 at 16:20
Every linear transformation $T:V^{(n)}\rightarrow W^{(m)}$ can be represented, with respect to two bases $\beta\in V$ and $\gamma \in W$, as a matrix $A_T$ of size $m\times n$. For each vector $v\in V$ and $w\in W$, their coordinates in respective bases are written in column vectors as $[v]^{\beta}\in \mathbb{R}^n$ and $[w]^{\gamma}\in \mathbb{R}^m$, and the linear transformation $u = T(v)$ is represented as a matrix multiplication $[u]^{\gamma} = A_T[v]^{\beta}$.
Conversely, every matrix $A_{m\times n}$ can be viewed as a linear transformation $T_A:\mathbb{R}^n\rightarrow \mathbb{R}^m$; indeed, all the matrix properties are derived from properties of linear transformations! As such, the matrix $A$ in the equation $y = Ax$ is by itself a linear transformation without the need of specifying the bases. (But you can always pick any two bases $\beta,\gamma$ and derive its "matrix-representation"; the simplest ones are the standard bases of $\mathbb{R}^n,\mathbb{R}^m$, in which $[A]_{\beta}^{\gamma}$ = A)
We have theorems and techniques for finite dimensional vector spaces that associate (a linear transformation + a basis) with a matrix. By mapping elements (via the choice of basis) to column vectors, we can compute the linear transformation's values by matrix-vector arithmetic. It is important to keep in mind that it is not simply linear transformation ~ matrix, but there is a choice of basis associated as well!
However matrices exist independent of linear transformations. They are just a funny way to write arrays of numbers, and they have their own rules and structures that can be studied.
Linear transformations likewise are simply special functions between vector spaces. They exist on their own, without regard for this special way to write them down.
Jason Knapp
  • 1,689
Write down the definition in an equivalent way as follows,
$$ T(x_1,\ldots \ldots,x_n) = \left({ \sum_{j=1}^{n} \mathbf T_{ 1j}~x_j~~, \sum_{j=1}^{n} \mathbf T_{2j}~x_j~~, \ldots \ldots, \sum_{j=1}^{n} \mathbf T_{mj}~x_j~~ }\right) $$
Then you should see that this is nothing but the Linear transformation defined by:
$$ T \left({ \begin{matrix} x_1 \\ x_2 \\ x_3 \\ . \\ . \\ x_n \\ \end{matrix}}\right) = \mathbf T \left({ \begin{matrix} x_1 \\ x_2 \\ x_3 \\ . \\ . \\ x_n \\ \end{matrix}}\right) $$
Now as long as you fix two bases $\mathfrak B_1 $ and $ \mathfrak B_1 $ for $ \Bbb R^n $ and $ \Bbb R^m $ this Linear Transformation is uniquely determined by the given matrix. Actually, fixing two bases we can define a bijection between the set $ \mathbb M_{mn}$ and the set of Linear Transformations from $ \Bbb R^n \to \Bbb R^m $. That means for each Linear Transformation $T$ "there exists one and exactly one" matrix $ \mathbf T \mathbb \in M_{mn} $ such that $ T(\underline x) = \mathbf T \underline x $ where $ \underline x $ is a column vector in $ \Bbb R^n $. Now all this is again as long as you fix two bases.
So essentially you're right. You need not differentiate between them at all as long as you are using the Standard Ordered Bases for the two Euclidean spaces, which I suspect you are.
Ishfaaq
  • 10,230
Linear transformation Just talk about XY plane. If I transform (rotate) X axis to 90 degree I will get Y axis it is a one of the linear transformation. Another example just draw a real line in some interval after that draw another line for same inerwal in scaled version, it is also a linear transformation. If we condiser in two dimention First example draw a square and draw rectangle also. If I say I transformed somehow square in rectangle then it is a linear transformation of square into rectangle. Second example draw square and circle and then I say I transformed square into circle then it is not a linear transformation of square into circle because linear sides of former are not not linear (they are curved now).
Matrix transformation is nothing but a transformation caused by matrix. Matrix transformation is alway linear transformation.
