This problem is in a chapter on the Greatest Common Divisor: The Euclidean Algorithm. Apparently I managed to arrive at one of the 3 possible solutions.
Problem goes 'man at a casino wins \$1020 in \$20 and 50 \$chips. if he has more \$50 than \$20 chips, how many chips of each denomination could he possibly have?'
To solve the problem I tried:
$$\gcd(20,50) = 10$$
so $20x + 50y = 10$
$$20(3) + 50(-1) = 10$$
so $20(306 - 50k) + 50(-102 + 20k) = 1020$
solved for $k$: must be $5.1\le k \le 6.12$ so one solution is if $k=6$ then $x=6$, $y=18$. (this is one of the solutions). there are two other solutions provided. not sure how to arrive at those. thanks.
miniparser
  • 1,217
  • 9
  • 18
Hint $\ $ By linearity, the general solution of $\ 20x + 50y = n\ $ arises by adding to any particular solution the general solution of the associated homogeneous equation $\, 20x + 50 y = 0,\,$ which is $\, (x,y) = (5n,-2n),\,$ by $\,\frac{y}x = \frac{\!\!\!-20}{50} = \frac{\!\!\!-2}5.\,$ So all other solutions arise by repeatedly adding or subtracting $\,(5,-2)\,$ to solution $\,(6,18),\,$ yielding further only $\,(1,20),\,(11,16)\,$ in your range $$\ \ \ \ \color{#0a0}{\ldots,(-4,22)},(1,20),(6,18),(11,16),\color{#c00}{(16,14),\ldots}$$ since further subtraction makes $\,\color{#0a0}{y < 0},\,$ further addition makes $\, \color{#c00}{x > y}$.
Bill Dubuque
  • 282,220
$50x+20y = 1020 \implies 5x+2y = 102$. Take $\pmod 2 \implies x = 2k$. Then $5k+y = 51$. Take $\pmod 5$ so $y = 5j+1$. Then $k+j = 10$ which parameterizes all solutions. Then just pick the ones based on your restrictions.
