As has been noted, since $(6,10)=2$ any amount of money used must be even. Assuming that, what is the largest even amount that cannot be paid?
Let's divide everything by $2$ so that we consider double coins of $3$ and $5$ value.
Theorem 1 below shows that if $(a,b)=1$ and $c\ge(a-1)(b-1)$, then $ax+by=c$ has a solution where $x,y\ge0$.
Since $(3-1)(5-1)=8$, any amount of $8$ or greater double coins can be paid. Thus, any even amount greater than or equal to $16$ can be paid.
Since $3\not\mid7$ and $5\not\mid7$ and $7\lt3\cdot5$, Theorem 2 says that only one of $7$ or $8$ can have a non-negative solution. Since $8$ has a non-negative solution, $7$ can't. Therefore, the largest even amount that can't be paid is $\mathbf{14}$.
Theorem 1:
Suppose $(a,b)=1$ and $c\ge(a-1)(b-1)$. Then $ax+by=c$ has a non-negative solution, that is, one in which both $x$ and $y$ are non-negative integers.
Proof:
Since $(a,b)=1$, we have some $(u,v)$ so that $au+bv=1$. The set of all
solutions to $ax+by=c$ is
\{(cu+bk,cv-ak):k\in\mathbb{Z}\}\tag{1}
Thus, we have a non-negative solution $(x,y)$ precisely when there is an integer $k$ so that
k\ge-cu/b\tag{2}
(so that $cu+bk\ge0$) and
k\le cv/a\tag{3}
(so that $cv-ak\ge0$). Thus, $ax+by=c$ has a non-negative solution iff
[-cu/b,cv/a]\cap\mathbb{Z}\ne\{\}\tag{4}
Suppose there is no integer in this interval. This means there must be a $j\in\mathbb{Z}$ so that
[-cu/b,cv/a]\subset(j,j+1)\tag{5}
Since $cu$ and $cv$ are integers,
we must have
-cu/b-j >= 1/b\tag{6}
and
j+1-cv/a >= 1/a\tag{7}
Adding $(6)$ and $(7)$ and multiplying by $ab$ gives
ab-cau-cbv\ge a+b\tag{8}
Since $au+bv=1$, $(8)$ becomes
c\le ab-a-b\tag{9}
Therefore, if $c\ge ab-a-b+1=(a-1)(b-1)$, then there is a non-negative
solution $(x,y)$ to $ax+by=c$.
QED
Theorem 2:
Suppose $(a,b)=1$, $0\lt c\lt ab$, and neither $a\mid c$ nor $b\mid c$. Then
one and only one of
ax+by=c\tag{10}
and
ax+by=ab-c\tag{11}
has a non-negative solution.
Proof:
Note that since neither $a\mid c$ nor $b\mid c$, neither $x$ nor $y$ can be $0$ in any solution. Therefore, any non-negative solution must be a positive solution, that is, one in which both $x$ and $y$ are positive integers.
Suppose both $as+bt=c$ and $au+bv=ab-c$ are positive solutions. Add them
together to get
a(s+u)+b(t+v)=ab\tag{12}
Since $(a,b)=1$, $(12)$ says that $b\mid s+u$ and $a\mid t+v$. Since $s$, $t$, $u$, and $v$ are positive integers, we must have that $s+u\ge b$ and $t+v\ge a$. However, then $a(s+u)+b(t+v)\ge2ab$, which contradicts $(12)$.
Therefore, we have shown that at most one of $(10)$ and $(11)$ can have a
Suppose $(10)$ does not have a non-negative solution. Since $(a,b)=1$,
we have some $(u,v)$ so that $au+bv=1$. The set of all solutions to $ax+by=c$
is then $\{(cu+bk,cv-ak):k\in\mathbb{Z}\}$. Therefore, we can find an $(s,t)$ so
that $as+bt=c$ and $0\le s\lt b$.
Since $bt=c-as$, we have that $-ab\lt bt\lt ab$. Since $(10)$ does not have
a non-negative solution, we must have $-ab\lt bt\lt 0$. Thus, we have the
non-negative solution $a(b-s)+b(-t)=ab-c$.
Therefore, we have shown that at least one of $(10)$ and $(11)$ must have a
QED
ab - a - bdoesn't hold. See my answer. – smci Mar 28 '14 at 16:25
