Definition . For $m ≥ 0$, the $m$th power-sum denominator is the smallest positive integer $d_m$ such that $d_m · (1^m + 2^m + · · · + n^m) $is a polynomial in $n$ with integer coefficients. The first few values of $d_m$ (see , Sequence A064538) are $d_m = 1, 2, 6, 4, 30, 12, 42, 24, 90, 20, 66, 24, 2730, 420, 90, 48, 510, . . . .$
Define $$\begin{split} S_m(n)&= 1^m+2^m+...+n^m \\ &= \frac{1}{d_m}\sum_{l=1}^{m+1} b_l n^{l} \end{split}$$
Can it be shown that
Let $n=d_mt+r$ where $t\ge0,r\ge 0$ then $S_m(n)$ may represent as
$$\begin{split} S_m(n)&= \sum_{l=1}^{m+1}(x_lt+y_l)n^{l-1}\end{split}$$
With $x_l$ and $ y_l$ are integers.
Example
Let $m=2$ gives $S_2(n)=\frac{n(n+1)(2n+1)}{6}\to d_2=6$
let $r=2\to n=6t+2$
And $S_2(n)=(2t+1)n^2+(t)n^1+(3t+1)n^0$
Here $x_1,x_2,x_3,y_1,y_2,y_3$ are $2,1,3,1,0,1$ respectively.
Anne Bauval
  • 49,005
Pruthviraj
  • 2,697
  • The Faulhaber polynomials have coefficients expressed in terms of the Bernouilli numbers. https://en.wikipedia.org/wiki/Faulhaber%27s_formula –  Aug 16 '24 at 21:53
Theorem 1: Given $b_1,b_2,...,b_m,b_{m+1}$ finite integers. Denominator $d$ is smallest positive integer for $b_l$ integer coefficient. consider $n=dt+r$ then
$$\sum_{0<l\le m+1}\binom{n}l a_l= \frac{1}d\sum_{0<l\le m+1}b_ln^{l}=\sum_{0<l\le m+1}(x_lt+y_l)n^{l-1}$$
With $x_u$ and $y_u$ integers.
Proof: Denote $$\sum_{0<l\le m+1} b_l(h+r)^{l}=\sum_{0<l\le m+1} c_l h^{l}$$
The numbers $c_l$ are still integers, and we have, denoting $dt+r=n$, $$ \frac1d\sum_{0<l\le m+1} b_l(dt+r)^{l}\\ =\frac1d\sum_{0<l\le m+1} c_l (dt)^l\\ =\sum_{0<l\le m+1} c_l t\cdot (dt)^{l-1}\\ =\sum_{0<l\le m+1} c_l t\cdot (n-r)^{l-1}\\ = \sum_{0<l\le m+1\\ 0\leqslant j\leqslant l-1} c_l {l-1\choose j}(-r)^{l-1-j}n^jt, \\ =\sum_{0<l\le m+1} (x_lt+y_l)n^{l-1}$$
Source link (MO post)
Formula
Let $n$ and $m$ are the integers with $n\geq 1$ and $m\geq 0$
$$\sum_{k=1}^{n} k^{m}=\sum_{l=1}^{m+1} \binom{n}l\sum_{i=0}^{l-1} (-1)^{i}(l-i)^{m}\binom{l-1}i$$
Proof link
Consider $$a_{l,m}=\sum_{i=0}^{l-1} (-1)^{i}(l-i)^{m}\binom{l-1}i$$
By theorem 1 $$S_m(n)=\sum_{l=1}^{m+1} \binom{n}la_{l,m}=\sum_{l=1}^{m+1}(x_lt+y_l)n^{l-1}$$
Pruthviraj
  • 2,697
