I am looking for problems that use induction in their proofs such as this one: Given a checker board with one square removed you can cover it with L-shaped pieces made out of three squares. This problem is very different from most induction problems which are algebra driven. Do you know of any other? I am looking for geometrical or algorithmic type problems.
3There is an amazing riddle which Randall Munroe have published in his blog xkcd (although he exaggerates when he calls it "the hardest logic puzzle in the world". (link). Its general case can be proven using induction. – Idan Feb 04 '13 at 17:33
3Can prove that if you cut the plane with straight lines then you can colour in each region such that no two regions which share an edge are the same colour – Ben Feb 04 '13 at 19:14
@tsho: +1 for any xkcd link...:) – gnometorule Feb 04 '13 at 19:35
2Examples of mathematical induction – MJD Feb 04 '13 at 20:22
1Here's the se.math answer to the "amazing riddle" referred to above: http://math.stackexchange.com/questions/238288/is-there-no-solution-to-the-hardest-puzzle – MJD Feb 04 '13 at 20:24
Some problems with some illustrative pictures provided below. All of the problems were taken from Daniel J. Velleman's excelent book How to Prove It: A Structered Approach.
$\textbf{Problem 1:}$ For all $n\in \mathbb{N}$, if $n\ge 3$, then if $n$ distinct points on a circle are connected in consecutive order with straight lines, then the interior angles of the resulting polygon add up to $(n-2)180º$.
Case $n=4$:
Inductive step:
$\textbf{Problem 2:}$ Let $n\in \mathbb{N}$. An equilateral triangle is cut into $4^n$ congruent equilateral triangles, and one corner is removed. Show that the remaining area can be covered by trapezoidal tiles that look like this:
Case $n=2$:
$\textbf{Problem 3:}$ Let $n\in \mathbb{N}$. Suppose $n$ chords are drawn in a circle in such a way that each chord intersects every other, but no three intersect at one point. Prove that the chords cut the circle into $\displaystyle \frac{n^2+n+2}{2}$ regions.
Case $n=4$:
$\textbf{Problem 4:}$ Let $n\in \mathbb{N}$ and suppose that $n$ chords are drawn in a circle, cutting the circle into a number of regions. Prove that the regions can be colored with two colors in such a way that adjacent regions (that is, regions that share an edge) are different colors.
Case $n=4$:
- 31,706
1The interior angles of any polygon add up to $\pi(n-2)$, the fact that it's inscribed in a circle is irrelevant. The proof suggested in the second picture works even if you forget about the circle. – Kevin Casto Oct 23 '15 at 03:18
You might want to look at this pdf: Structure of Proof by Induction, which provides both "traditional, formula based" induction to help explain the logic of inductive proofs, but starts with, and includes some scattered examples of its applicability to recursive-type algorithms and counting arguments: domino problem, coin-change problem.
Indeed, the correctness of the recursive algorithm for solving the Tower of Hanoi Problem boils down to proof by induction (see logical analysis of recursive solution). Inductive proofs are also often used in graph theory.
See also this post linking you to a previous post asking for examples of mathematical induction. You'll get some rich mix of problem types, and see the breadth of its utility!
These induction proofs are interesting. Look at examples.
Prove that every integer greater than 2 can be written as product of primes.(Strong Induction)
Prove than every integer greater than 12 can be made as sum of 4 and 5s.(The original one has to do with coins and postage stamps)
