Suppose there exists a Lebesgue Space, $L_1$ and functions functions $\phi$, $\phi'$, $f$, and $f'$ functions where $$\phi, \phi' \in L_1$$
By rule of integration by parts, $$uv|_a^b = \int_a^b udv + \int_a^b vdu$$
Let $$ u = \phi, du= \phi'$$ $$ v = f, dv = f'$$
Are there any properties of Lebesgue functions that allow
$$ uv|_a^b = 0$$
Are $\phi$ and $\phi'$ convergent as integrals? Do the unbounded limits of $\phi$ and $\phi'$ converge?
Mittens
  • 46,352
Jeremy
  • 329
Integration by parts from the point of view of Lebesgue integration is more appropriately understood in terms of functions of local finite variation. Here is a version and then I comment more on your particular problem. I hope this is helpful to you.
Theorem: Let $F$, $G$ be right--continuous functions of locally finite variation on an interval $I$ (bound or unbounded) Let $\mu_F$ and $\mu_G$ the Stieltjes-Lebesgue measures generated by $F$ and $G$ respectively. For any bounded interval $(a,b]\subset I$, $$ \int_{(a,b]}F(t)\mu_G(dt)=F(b)G(b)-F(a)G(a)-\int_{(a,b]}G(t-)\mu_F(dt) $$ where $G(t-)=\lim_{s\nearrow t}G(s)$.
A proof can be obtained using Fubini's theorem \begin{align} (F(b)-F(a))(G(b)&-G(a))=\int_{(a,b]\times(a,b]}\mu_F\otimes\mu_G(dt,ds)\\ &=\int_{(a,b]}\Big(\int_{(a,s]}\mu_F(dt)\Big)\mu_G(ds) +\int_{(a,b]}\Big(\int_{(s,b]}\mu_F(dt)\Big)\mu_G(ds)\\ &=\int_{(a,b]}\Big(\int_{(a,s]}\mu_F(dt)\Big)\mu_G(ds) +\int_{(a,b]}\Big(\int_{(a,t)}\mu_G(ds)\Big)\mu_F(dt)\\ &=\int_{(a,b]} F(s)-F(a)\mu_G(ds) +\int_{(a,b]}G(t-)-G(a)\mu_F(dt)\tag*{$\blacksquare$}\\ \end{align}
Comment: Some useful variant are obtained by noticing that for any point $x\in I$, $\mu_G(\{x\})=G(x)-G(x-)=\Delta G(x)$, $\mu_F(\{x\})=F(x)-F(x-)=\Delta F(x)$. For example, \begin{align} \int_{(a,b]}F(t)\mu_G(dt)&=F(b)G(b)-F(a)G(a)-\int_{(a,b]}G(t)\mu_F(dt)+\sum_{a<t\leq b}\Delta G(t)\Delta F(t) \end{align} If $[a,b]\subset I$, \begin{align} \int_{[a,b]}F(t)\mu_G(dt)&=F(b)G(b)-F(a-)G(a-)-\int_{[a,b]}G(t-)\mu_F(dt)\\ \int_{(a,b)}F(t)\mu_G(dt)&=F(b-)G(b-)-F(a)G(a)-\int_{(a,b)}G(t-)\mu_F(dt)\\ \int_{[a,b)}F(t)\mu_G(dt)&=F(b-)G(b-)-F(a-)G(a-)-\int_{[a,b)}G(t-)\mu_F(dt) \end{align}
In the setting that you have in mind, you may have $\phi$ and $\psi$ that are absolutely continuous in an interval $[c,d]$. Then $f=\phi'$ and $g=\phi'$ exists a.s. (with respect the Lebesgue measure in $\mathbb{R}$) and \begin{aligned} \phi(x)&=\phi(c)+\int^x_cf(t)\,dt,&\qquad c\leq x\leq d\\ \psi(x)&=\psi(c)+\int^x_cg(t)\, dt,& \qquad c\leq x\leq d \end{aligned} Then you may consider $F(x)=\phi(x)$ and $G(x)=\psi(x)$ in which case \begin{aligned} \mu_F((dt) &= \phi(c)\delta_c(dt) + f\mathbb{1}_{(c,d]}(t)\,dt\\ \mu_G(dt) &=\psi(c)\delta_c(dt) + g\mathbb{1}_{(c,d]}(t)\,dt \end{aligned} Applying the theorem above, you recover the usual integration by parts formula for $[a,b]\subset[c,d]$.
As for the boundary condition $\phi(t)\psi(t)|^b_a=0$, there many instances in which that happens. The important thing is to notice that $\phi$ and $\psi$ should be absolutely continuous to begin with.
For infinite intervals one has to use dominated convergence (integrability conditions on the derivatives $\phi'=f$ and $\psi'=g$) type of arguments. Typical situations are when both $|\mu_F|$ and $|\mu_F|$ are finite measures.
Mittens
  • 46,352
It is not true in general that $\phi \in L_1(\mathbb{R})$ implies $\lim_{x \to \infty} \phi (x) = 0$. The limit may not exist. For example, let $\phi (x) = 1$ for $x \in [n, n+2^{-n})$ for each natural number $n$ (including zero), and let $\phi \equiv 0$ otherwise. Then, we have
\begin{equation*} \int_{-\infty}^\infty |\phi| = \sum_{n=0}^\infty 2^{-n} = 2 < \infty, \end{equation*} but $\lim_{x \to \infty} \phi (x)$ does not exist. In fact, we can modify this example to construct an unbounded function which has no limit at infinity but belongs to $L^p$ for every finite $p$.
It is not clear to me what your question is. Typically the situations in which boundary terms for integration by parts vanish are when we know the functions are periodic (e.g. they are solutions to a PDE on which we impose periodic boundary conditions) or when one of the functions is compactly supported on the domain of integration.
Montie
  • 450
By the definition of Lebesgue spaces,
If $\phi \in L_1$ then $\int_{-\infty}^{\infty} \phi(x)\, dx < \infty$
If $\lim_{x \to \infty} \phi(x) > 0$ or $\lim_{x \to \infty} \phi(x) < 0$ then $\int_{-\infty}^\infty |\phi(x)| dx = \infty$
The contrapositive of the preceding statement is $ \int_{-\infty}^\infty | \phi(x) | dx \ne \infty$ then $\lim_{x \to \infty} \phi(x) = 0$
Integration by parts is usually applied as $a = -\infty$ and $b = \infty$ $uv|_{\infty}^{\infty}$ will evaluate to 0 because the unbounded integral of $\phi(x)$ converges.
Jeremy
  • 329
