Yes, I have seen that this question has been asked and answered before in this same website, but answers given there were mostly in regards to geometry, or non-mathematical examples (e.g. "the 'e's in the word 'between' are congruent, but not equal", "two triangles with the same dimensions and points are equal").
I can understand this just fine, but I can't use this advice when it comes to pure numbers, like mods. For example: $17 \equiv 5 (mod(6))$. How is this statement correct? If we solve $5 (mod(6))$ we get $5$, so that would mean $17 \equiv 5$.
Also, $17 \equiv 4(mod(13))$, which means $17 \equiv 4$, and $17 \equiv 3(mod(7))$, which is $17 \equiv 3$
So then, $17 \equiv 5 \equiv 4 \equiv 3$ is true? That doesn't seem right. Are all positive integers congruent to one another?
I know this may seem like a simple matter to some, but I'm seriously stuck.
    The equal sign is not used because the numbers are not strictly equal, the numbers fall under the same equivalence relation. When, you talk about the number 1 modulo 5, you are talking about the set of numbers $${\dots,-9,-4,1,6,11,17,\dots}$$ all at once. – Jonathan Davidson Jun 24 '17 at 18:45
  • So when you use the $\equiv$ you just mean that the two numbers (or expressions) are part of the same set? So, could I also technically write $$1 \equiv 2 \gt 0$$ as a true statement? – Joao Eanes Jun 24 '17 at 18:51
  • @JoaoEanes How are you interpreting that statement? – Jack M Jun 24 '17 at 19:16
I think that you are misunderstanding the meaning of $\equiv$ in number theory. The statement $$17\equiv5\equiv4\equiv3$$ has no meaning whatsoever. Neither does the statement $17\equiv 4$. The essential part is the $\bmod$ at the end. The statement $$a\equiv b(\bmod c)$$ means "the remainder of $a \div c$ is equal to the remainder of $b \div c$". So when you exclude the "mod", you are refraining from specifying what is being divided by, which is an essential part of the statement.
However, you could say that since $$17 \equiv 4 (\bmod 13)$$ and $$17 \equiv -9 (\bmod 13)$$ then $$4 \equiv -9 (\bmod 13)$$ The modulus is an essential part of the statement, though.
Franklin Pezzuti Dyer
  • 40,930
  • 9
  • 80
  • 174
