I have the points:
$A(0,0,1), B(0,1,0), C(2,0,0)$
I am asked to find the scalar equation of the plane but I cannot use cross product to compute the normal vector. How do I do it without it?
Let:
$AB = [0,1,-1], AC = [2,0,-1]$
Let $n$ be the normal vector $[n_{1}, n_{2}, n_{3}]$
I know, $AB \cdot n = 0, AC \cdot n = 0 $.
How can I find the normal vector?
K Split X
  • 6,675
    You find it by solving the two equations (in three unknowns) given by $AB \cdot n = 0, AC \cdot n = 0$ and choosing any non-zero solution. – Arthur Jan 25 '17 at 01:01
If $n=(n_1,n_2,n_3)$, then $$\begin{cases} \overrightarrow{AB}\cdot n=0 \\ \overrightarrow{AC}\cdot n=0\end{cases}\Leftrightarrow \begin{cases} n_2-n_3=0 \\ 2n_1-n_3=0\end{cases}$$ $$\Leftrightarrow \begin{cases}n_1=\lambda \\ n_2=2\lambda\\n_3=2\lambda\end{cases}\quad (\lambda\in\mathbb{R})\Leftrightarrow n=\lambda(1,2,2)\quad (\lambda\in\mathbb{R}).$$ Choosing for example $\lambda=1$, we get $n=(1,2,2).$
  • i think it would be helpful to point out that the normal vector is not supposed to be uniquely determined. Any normal vector would do. – M.Hamza Ali Jun 05 '18 at 23:26
You don't need normal vectors. Clearly $\overrightarrow{AB}$ and $\overrightarrow{AC}$ are linearly independent. So, they span the plane containing $A,B,C$, and a point $X=(x,y,z)$ lies on the plane if and only if $\overrightarrow{AX}=(x,y,z-1),\ \overrightarrow{AB}=(0,1,-1)$ and $\overrightarrow{AC}=(2,0,-1)$ are linearly dependent. Hence the equation of the plane is given by $$ \left|\begin{matrix}x&y&z-1\\ 0&1&-1\\ 2&0&-1\end{matrix}\right|=0. $$
user1551
  • 149,263
Another way is to use the Gram–Schmidt process. This is more complicated (unnecessarily so) but offers another perspective, constructing the normal vector starting with any vector not parallel to the plane by subtracting the parts parallel to the plane using vector projections.
With $\vec v_1=\overrightarrow{AB}=[0,1,-1]$, $\vec v_2=\overrightarrow{AC}=[2,0,-1]$, and $\vec v_3$ any vector not in the span of $\{\vec v_1,\vec v_2\}$, Gram–Schmidt produces mutually perpendicular vectors $\{\vec u_1,\vec u_2,\vec u_3\}$ such that the span of $\{\vec u_1,\vec u_2\}$ is the same as the span of $\{\vec v_1,\vec v_2\}$, and such that $\vec u_3$ is perpendicular to $\vec u_1$ and $\vec u_2$, and hence to the plane.
E.g., take $v_3=[1,0,0]$ and get
$$\begin{align*} \vec u_1=\vec v_1&=[0,1,-1];\\ \vec u_2=\vec v_2-\dfrac{\vec v_2\cdot \vec u_1}{\|\vec u_1\|^2}\vec u_1 &=\left[2,-\frac12,-\frac12\right];\\ \vec u_3=\vec v_3-\dfrac{\vec v_3\cdot \vec u_1}{\|\vec u_1\|^2}\vec u_1 -\dfrac{\vec v_3\cdot \vec u_2}{\|\vec u_2\|^2}\vec u_2 &=\left[\frac19,\frac29,\frac29\right]. \end{align*}$$
So you can take as normal vector any multiple of the last vector, e.g. $[1,2,2]$ as the simpler answer concluded.
Jonas Meyer
  • 55,715
  • Hi @JonasMeyer please can you help with this https://math.stackexchange.com/q/4396103/585488 – linker Mar 06 '22 at 12:09
