13
The inequality:
$$\left(\frac{a}{a+b+c}\right)^2+\left(\frac{b}{b+c+d}\right)^2+\left(\frac{c}{c+d+a}\right)^2+\left(\frac{d}{d+a+b}\right)^2\ge\frac{4}{9}$$ Conditions: $a,b,c,d \in \mathbb{R^+}$
I tried using the normal Cauchy-Scharwz, AM-RMS, and all such.. I think I can do it using some bash method like expanding the LHS and then maybe to go with homogeneity, normalization and then Muirhead, Jensen or something I dont know since I didn't go that way..
But can someone help me with a nice elegant solution. This is an olympiad question I was trying to solve, but couldn't manage an elegant solution.
Mathejunior
  • 3,354
By Holder inequality,we have $$\left(\sum\dfrac{a^2}{(a+b+c)^2}\right)\left(\sum a(a+b+c)\right)^2\ge \left(\sum_{cyc} a^{\frac{4}{3}}\right)^3$$ therefore $$\sum\dfrac{a^2}{(a+b+c)^2}\ge\dfrac{(a^{4/3}+b^{4/3}+c^{4/3}+d^{4/3})^3}{[(a+c)^2+(b+d)^2+(a+c)(b+d)]^2}$$ use Holder we have $$a^{\frac{4}{3}}+c^{\frac{4}{3}}\ge 2\left(\dfrac{a+c}{2}\right)^{\frac{4}{3}}$$ $$b^{\frac{4}{3}}+d^{\frac{4}{3}}\ge 2\left(\dfrac{b+d}{2}\right)^{\frac{4}{3}}$$if setting $$t^3=\dfrac{(a+c)}{b+d}$$,we have $$\sum_{cyc}\dfrac{a^2}{(a+b+c)^2}\ge\dfrac{1}{2}\cdot\dfrac{(t^4+1)^3}{(t^6+t^3+1)^2}$$ it remain to show that $$9(t^4+1)^3\ge 8(t^6+t^2+1)^2,t>0$$ or $$9\left(t^2+\dfrac{1}{t^2}\right)^3\ge 8\left(t^3+\dfrac{1}{t^3}+1\right)^2$$ let $u=t+\dfrac{1}{t}\ge 2$ the above ineuqality becomes $$9(u^2-2)^2\ge 8(u^3-3u+1)^2$$ or $$(u-2)^2(u^4+4u^3+6u^2-8u-20)\ge 0$$ since $$u^4+4u^4+6u^2-8u-20=u^4+4u^2(u-2)+4u(u-2)+10(u^2-2)\ge 0$$
math110
  • 94,932
  • 17
  • 148
  • 519
Trying the Buffalo Way suggested in the comments.
Assume without loss of generality that $a\le b\le c\le d$.
Let $a=x_1$, $b=x_1+x_2$, $c=x_1+x_2+x_3$, $d=x_1+x_2+x_3+x_4$. So $x_i\ge0,i\in[1,4]$
When then want to consider the sign of:
$$\left(\frac{x_1}{3x_1+2x_2+x_3}\right)^2+\left(\frac{x_1+x_2}{3x_1+3x_2+2x_3+x_4}\right)^2+\left(\frac{x_1+x_2+x_3}{3x_1+2x_2+2x_3+x_4}\right)^2+\left(\frac{x_1+x_2+x_3+x_4}{3x_1+2x_2+x_3+x_4}\right)^2-\frac{4}{9}$$
Using brute force gives a disgusting fraction with denominator of:
$$9 (3 x_1+2 x_2+x_3)^2 (3 x_1+2x_2+x_3+x_4)^2 (3 x_1+2 x_2+2x_3+x_4)^2 (3 x_1+3 x_2+2 x_3+x_4)^2$$
and has156 terms in the numerator:
$$4374x_1^6x_2^2+20412x_1^5x_2^3+39366x_1^4x_2^4+40176x_1^3x_2^5+22896x_1^2x_2^6+6912x_1x_2^7+864x_2^8+8748x_1^6x_2x_3+53946x_1^5x_2^2x_3+129600x_1^4x_2^3x_3+158598x_1^3x_2^4x_3+105516x_1^2x_2^5x_3+36456x_1x_2^6x_3+5136x_2^7x_3+8748x_1^6x_3^2+65610x_1^5x_2x_3^2+191727x_1^4x_2^2x_3^2+280260x_1^3x_2^3x_3^2+218367x_1^2x_2^4x_3^2+86820x_1x_2^5x_3^2+13868x_2^6x_3^2+26244x_1^5x_3^3+131058x_1^4x_2x_3^3+258876x_1^3x_2^2x_3^3+250614x_1^2x_2^3x_3^3+118584x_1x_2^4x_3^3+21944x_2^5x_3^3+32481x_1^4x_3^4+118908x_1^3x_2x_3^4+162774x_1^2x_2^2x_3^4+98148x_1x_2^3x_3^4+21925x_2^4x_3^4+21222x_1^3x_3^5+55566x_1^2x_2x_3^5+48414x_1x_2^2x_3^5+13982x_2^3x_3^5+7713x_1^2x_3^6+13050x_1x_2x_3^6+5509x_2^2x_3^6+1476x_1x_3^7+1220x_2x_3^7+116x_3^8+7290x_1^5x_2^2x_4+28350x_1^4x_2^3x_4+43740x_1^3x_2^4x_4+33480x_1^2x_2^5x_4+12720x_1x_2^6x_4+1920x_2^7x_4+8748x_1^6x_3x_4+52488x_1^5x_2x_3x_4+143370x_1^4x_2^2x_3x_4+209952x_1^3x_2^3x_3x_4+167958x_1^2x_2^4x_3x_4+69000x_1x_2^5x_3x_4+11384x_2^6x_3x_4+39366x_1^5x_3^2x_4+180306x_1^4x_2x_3^2x_4+341172x_1^3x_2^2x_3^2x_4+325512x_1^2x_2^3x_3^2x_4+154296x_1x_2^4x_3^2x_4+28848x_2^5x_3^2x_4+64476x_1^4x_3^3x_4+225504x_1^3x_2x_3^3x_4+300762x_1^2x_2^2x_3^3x_4+179304x_1x_2^3x_3^3x_4+39998x_2^4x_3^3x_4+52002x_1^3x_3^4x_4+132408x_1^2x_2x_3^4x_4+113484x_1x_2^2x_3^4x_4+32534x_2^3x_3^4x_4+22302x_1^2x_3^5x_4+37044x_1x_2x_3^5x_4+15474x_2^2x_3^5x_4+4878x_1x_3^6x_4+3982x_2x_3^6x_4+428x_3^7x_4+4374x_1^6x_4^2+18954x_1^5x_2x_4^2+39123x_1^4x_2^2x_4^2+48276x_1^3x_2^3x_4^2+35658x_1^2x_2^4x_4^2+14280x_1x_2^5x_4^2+2360x_2^6x_4^2+24786x_1^5x_3x_4^2+98172x_1^4x_2x_3x_4^2+166212x_1^3x_2^2x_3x_4^2+147888x_1^2x_2^3x_3x_4^2+67668x_1x_2^4x_3x_4^2+12504x_2^5x_3x_4^2+51759x_1^4x_3^2x_4^2+167184x_1^3x_2x_3^2x_4^2+210438x_1^2x_2^2x_3^2x_4^2+121080x_1x_2^3x_3^2x_4^2+26558x_2^4x_3^2x_4^2+51192x_1^3x_3^3x_4^2+124074x_1^2x_2x_3^3x_4^2+102816x_1x_2^2x_3^3x_4^2+28928x_2^3x_3^3x_4^2+25911x_1^2x_3^4x_4^2+41676x_1x_2x_3^4x_4^2+17072x_2^2x_3^4x_4^2+6486x_1x_3^5x_4^2+5190x_2x_3^5x_4^2+637x_3^6x_4^2+5832x_1^5x_4^3+20574x_1^4x_2x_4^3+30780x_1^3x_2^2x_4^3+24642x_1^2x_2^3x_4^3+10488x_1x_2^4x_4^3+1864x_2^5x_4^3+19764x_1^4x_3x_4^3+58320x_1^3x_2x_3x_4^3+67752x_1^2x_2^2x_3x_4^3+36756x_1x_2^3x_3x_4^3+7792x_2^4x_3x_4^3+25596x_1^3x_3^2x_4^3+57996x_1^2x_2x_3^2x_4^3+45636x_1x_2^2x_3^2x_4^3+12442x_2^3x_3^2x_4^3+15606x_1^2x_3^3x_4^3+23916x_1x_2x_3^3x_4^3+9506x_2^2x_3^3x_4^3+4488x_1x_3^4x_4^3+3488x_2x_3^4x_4^3+494x_3^5x_4^3+2916x_1^4x_4^4+7938x_1^3x_2x_4^4+8469x_1^2x_2^2x_4^4+4272x_1x_2^3x_4^4+864x_2^4x_4^4+6480x_1^3x_3x_4^4+13572x_1^2x_2x_3x_4^4+9984x_1x_2^2x_3x_4^4+2608x_2^3x_3x_4^4+5148x_1^2x_3^2x_4^4+7380x_1x_2x_3^2x_4^4+2816x_2^2x_3^2x_4^4+1728x_1x_3^3x_4^4+1292x_2x_3^3x_4^4+214x_3^4x_4^4+648x_1^3x_4^5+1242x_1^2x_2x_4^5+840x_1x_2^2x_4^5+208x_2^3x_4^5+864x_1^2x_3x_4^5+1128x_1x_2x_3x_4^5+408x_2^2x_3x_4^5+354x_1x_3^2x_4^5+252x_2x_3^2x_4^5+50x_3^3x_4^5+54x_1^2x_4^6+60x_1x_2x_4^6+20x_2^2x_4^6+30x_1x_3x_4^6+20x_2x_3x_4^6+5x_3^2x_4^6$$
All the co-efficients of the terms are positive and $x_i\ge0,i\in[1,4]$ so the entire expression is positive.
Reflection
Buffalo Way is terrible.
Also I don't know how to format that eyesore of a numerator nicely on this site.
Ian Miller
  • 12,140
  • @mixedmath Is there a way to put mathjax inside a horizontally scrolling box? I couldn't work it out. – Ian Miller Jan 14 '17 at 01:17
  • No, there isn't a way. – davidlowryduda Jan 14 '17 at 03:22
    To the downvoter can you please indicate what is actually wrong with my calculations? I have acknowledged they are very inefficient and that it is a terrible technique (Blame the person who originally suggested it would work not me). I don't believe there is anything technically wrong with the calculations so if you did repeat them and find an error please let me know. – Ian Miller Jan 22 '17 at 00:11
Let $\{a,b,c,d\}=\{x,y,z,t\}$, where $x\geq y\geq z\geq t$, $x+y+z+t=4$, $x+t=2u$ and $y+z=2v$.
Hence, $u+v=2$ and by Rearrangement we obtain: $$\sum\limits_{cyc}\frac{a^2}{(a+b+c)^2}\geq\frac{x^2}{(x+y+z)^2}+\frac{y^2}{(x+y+t)^2}+\frac{z^2}{(x+z+t)^2}+\frac{t^2}{(y+z+t)^2}=$$ $$=\frac{x^2}{(4-t)^2}+\frac{t^2}{(4-x)^2}+\frac{y^2}{(4-z)^2}+\frac{z^2}{(4-y)^2}$$ and since $$\frac{x^2}{(4-t)^2}+\frac{t^2}{(4-x)^2}\geq\frac{-2(x+t)^2+16(x+t)-16}{(8-x-t)^2} \tag1$$ it's just $$((x+t)(x^2+t^2)-12(x^2+xt+t^2)+48(x+t)-64)^2\geq0, \tag2$$ it remains to prove that $$\frac{-2u^2+8u-4}{(4-u)^2}+\frac{-2v^2+8v-4}{(4-v)^2}\geq\frac{4}{9},\tag3$$ where $u$ and $v$ are positive numbers such that $u+v=2$ or $$\sum_{cyc}\left(\frac{-2u^2+8u-4}{(4-u)^2}-\frac{2}{9}\right)\geq0$$ or $$\sum\limits_{cyc}\frac{(u-1)(17-5u)}{(4-u)^2}\geq0$$ or $$\sum\limits_{cyc}\left(\frac{(u-1)(17-5u)}{(4-u)^2}-\frac{4}{3}(u-1)\right)\geq0$$ or $$\sum_{cyc}\frac{(u-1)^2(13-4u)}{(4-u)^2}\geq0.$$ Done!
Hans
  • 10,484
  • Would you mind adding some explanation of what motivates the brilliant and insightful steps Equations (1), (2) and (3)? Could you also reveal your tricks for proving these inequalities without brute force? Thank you. – Hans Aug 03 '17 at 08:11
  • @Hans The motivation is a clear enough: we want to reduce a number of variables and to make a sum of squares. But I remember releasing of this idea was very hard for me. I remember that I used brute force for the verification. – Michael Rozenberg Aug 03 '17 at 08:31
