Is it possible to have a chart with
  • left Y axis
  • right Y axis
  • top X axis
  • bottom X axis
all on same chart?
Ale
  • 776
Loretta
  • 41
If I have understand well you have two different datasets to compare on the same chart.
If so
  1. You can make your XY chart with both dataset.
  2. Then double click on one series, and on the Axis tab, select Secondary. It appears a secondary Y axis.
  3. Select "Chart Manu/Chart Options/Axes tab", uncheck the secondary Y box, and check the secondary X box.
Example showing two X and Y axes
Andi Mohr
  • 4,315
Ale
  • 776
