If I press CRTL+Down I move to the cell before the empty cell.
If I press CTRL+SHIFT+End I end up selecting everything between the active cell and the next empty cell.
Now if I want to auto fill the same range of cells, what is the keyboard shortcut for that? (Autofill; also known as clicking the handle in the lower right hand corner of the cell and dragging)
leeand00
  • 23,552
There a two different function that can be performed using this part of the GUI
1st
Fill using formula
Starting point:
pre-cdfill
ctrl + D
2nd
Fill sequence:
Starting point:
Alt>H>F>I>S Then shift+tab>down>down>down>Enter
Personally I see the sequence fill as to cumbersome so below is a quick macro to do the same
Sub dragSeries()
    Selection.DataSeries Rowcol:=xlColumns, Type:=xlAutoFill, Date:=xlDay, _
        Trend:=False
End Sub
Just assign it to say ctrl+shift+D and enjoy
50-3
  • 3,999
