11
I'm writing a script that needs to be executed using source, because its task is to modify the environment. During the script, I want to use set -e so that any error stops the script. The script looks like this:
#!/bin/bash
set -e
# do something
cd somewhere
source anotherScript
The problem is that set -e naturally remains in effect after the script finishes. How can I ensure that the altered set option is properly restored to its prevous value when the script stops (in any way - either by completing successfully or on an error)?
Petr
  • 3,273
4 Answers4
17
The command set +o lists the current settings as commands that restore the same state, e.g.
$ set +o
set +o allexport
set -o braceexpand
set -o emacs
set +o errexit
set +o errtrace
You can easily restore all the options later, if you save this output to a shell variable:
SAVED_OPTIONS=$(set +o)
set -e
# do something
eval "$SAVED_OPTIONS"
Bash includes also a number of non-standard (not POSIX) options that are adjusted using shopt command. The command shopt -p can be used to save these options in a similar fashion.
If you only want to save and restore one option, you can use the $- environment variable, which lists the current set of options as letters, e.g.
$ echo $-
himBH
You could use something like this to save and restore a particular option:
[[ $- = *e* ]]
SAVED_ERREXIT=$?
set -e
# do something
(( $SAVED_ERREXIT )) && set +e
Use a RETURN trap
RETURN traps work for sourced scripts, too.
Commands specified with an RETURN trap are executed before execution resumes after a shell function or a shell script executed with . or source returns.
https://www.gnu.org/software/bash/manual/bash.html
main_script.sh
#!/usr/bin/env bash
echo "inside main script"
shopt -o errexit
source a_script_to_be_sourced.sh
echo "back inside main script"
shopt -o errexit
trap "$(shopt -p -o errexit)" RETURN
set -e # Equivalents: set -o errexit; shopt -s -o errexit
echo "inside sourced script"
shopt -o errexit
Test
$ ./main_script.sh
inside main script
errexit         off
errexit         on
errexit         off
Exactly the same way you activate it: calling the buitin set:
$ set -o errexit
$ set -o | grep errexit
errexit         on
$ set +o errexit
errexit         off
From the bash(1) manpage, under the SHELL BUILTIN COMMANDS section, `set' command:
-o option-name
The option-name can be one of the following:
    errexit Same as -e.
dawud
  • 1,518
Restoring previous activated settings can be quickly done as:
PREV_SETTING=$-  # e.g. himxBH  (there was xtrace)
set +x
# do your script without xtrace, ...
set -$PREV_SETTING
The other way around (restore to the off state) AFAIK there isn't such a shortcut and Seppo's answer covers all cases.
F Pereira
  • 121
