I'm going to buy a new SD card to be used in my car's audio player. What I would like to know is, if I buy a micro SD card with adapter, will it provide the same read/write speed as a standard SD card of the same model? Does using adapter affect speed?
Asked
Active
Viewed 5,682 times
11
The adapter is basically just a bunch of wires; they use the same signaling. The class of the device will determine the speed, not the adapter.
Ignacio Vazquez-Abrams
- 114,604
As far as my experience goes, there's no difference between using an SD card vs a micro SD card.
I've even booted full linux distributions from a micro-sd card (8GB) with a SD adapter
bbonamin
- 887
