After researching multiple sources it seems MSI A320M VD/S m-atx motherboard should be able to be used with 2 mic inputs and 3 audio outputs at the same time - 2 front ports, 3 rear ports.
However I could only get front or back to work, not both at the same time.
msi realtek audio consol screenshot
After trying different options, this solution solved it! How to get headphones and speakers working at the same time?
  • in Realtek audio console,
  • click on the settings option near the ports
  • check the option "Disable the front panel popup dialog"
Now both front and back audio ports play the same sounds at the same time.
disable front panel popup dialog
I have previously used an application called Voicemeter which can be used for audio routing, I used it to output audio to my TV via HDMI and to a USB headset at the same time.
