When trying to test the speed of functions, I found that not all parts of my code work in Release mode. The same code works perfectly in Debug mode, though.
I'm using VC++ compiler with /O2 optimization.
Here's the cut out part, which doesn't work.
int main()
boost::timer::auto_cpu_timer t;
for(int i = 0; i < 1000000; i++)
gcdb(i, 5);
return 0;
The generated assembly in release mode, the code for the for loop is missing only in this mode.
int main()
000000013F8E1280 sub rsp,88h
000000013F8E1287 mov rax,qword ptr [__security_cookie (013F8E7150h)]
000000013F8E128E xor rax,rsp
000000013F8E1291 mov qword ptr [rsp+70h],rax
000000013F8E1296 lea rcx,[t]
000000013F8E129B mov edx,6
000000013F8E12A0 call boost::timer::auto_cpu_timer::auto_cpu_timer (013F8E2DA0h)
gcdb(i, 5);
return 0;
000000013F8E12A5 lea rcx,[t]
000000013F8E12AA call boost::timer::auto_cpu_timer::~auto_cpu_timer (013F8E2810h)
000000013F8E12AF xor eax,eax
gcdb() is just a function for the finding the GCD of two numbers.
What could be causing this code skipping?
