I have a base table with invoices for different stock codes, the important fields are:
| StockCode | InvoiceDate |
| AAA | 2022-01-01 |
| AAA | 2022-05-01 |
| BBB | 2022-02-01 |
| BBB | 2022-11-01 |
I am trying to work back to the cost price of those items using an amendment journal which records the changes to cost of the material. The amendment journal looks like this:
| StockCode | JnlDate | Before | After |
| AAA | 2022-02-01 | 10.000 | 11.000 |
| AAA | 2022-06-01 | 11.000 | 12.000 |
| BBB | 2022-03-01 | 20.000 | 21.000 |
| BBB | 2022-11-02 | 21.000 | 22.000 |
What I would like to do is to use OUTER APPLY to get the first amendment that occurs after the sale and get the [Before] price - which would be the price at that time. If there are no amendments after the invoice, I am able to make use of its current material cost on the system using ISNULL on the joined [Before] value.
My current code looks like this:
WITH
allChanges AS
-- Need to convert the varchar to numeric in the amendment journal
SELECT StockCode, JnlDate,
CONVERT(DECIMAL(18,6),REPLACE([Before],',','')) AS [Before],
CONVERT(DECIMAL(18,6),REPLACE([After],',','')) AS [After]
FROM InvMastAmendJnl
WHERE CostType = 'MaterialCost'
invoices AS
SELECT Invoice, StockCode, InvoiceDate FROM InvoiceTable
-- Begin query
FROM invoices
OUTER APPLY
SELECT TOP(1) [Before] AS MaterialCost
FROM allChanges
WHERE allChanges.StockCode = invoices.StockCode AND allChanges.JnlDate > invoices.InvoiceDate
ORDER BY JnlDate ASC
Important points:
- When I execute each temporary tables (allChanges and invoices) individually there are no conversion errors.
- When I run the code above the following error occurs: "Error converting data type varchar to numeric."
- If I remove the TOP(1) and ORDER BY statements, there are no errors, but i get all the amendments which occured after the sales date being joined to the table.
- If I limit the full query to a single stock code, and leave TOP(1) and ORDER BY, e.g. WHERE StockCode = 'AAA', then there also isn't any conversion error.
Ultimately, what I want is a single value to return and be joined to the base table, so I need to get a single value from the outer apply for each row - what should I do?
