- My project workspace folder is located at
D:\salix\fantasy. - My TypeScript configuration file is located at
D:\salix\fantasy\tsconfig.json
No matter what I do, I can't seem to get the problem matcher for my project to resolve to the correct location. For some reason the TypeScript compiler is reporting the full path, relative to the drive root, for each error it encounters, and vscode is attempting to treat those paths as relative to the workspace folder. As such, I can't click on a problem without getting "file not found", because the error paths are being reported like this:
Here is my tsconfig.json file, which is in the workspace root, as standard:
"compilerOptions": {
"module": "ESNext",
"target": "ESNext",
"strictNullChecks": true,
"exactOptionalPropertyTypes": true,
"sourceMap": true,
"moduleResolution": "Node",
"removeComments": true,
"outDir": "dist",
"include": [
"source/**/*.ts",
"exclude": [
"node_modules",
"**/node_modules/*",
"source/shared/libraries/*",
Here is my tasks.json file:
"version": "2.0.0",
"tasks": [
"label": "Server",
"type": "typescript",
"tsconfig": "tsconfig.json",
"option": "watch",
"problemMatcher": "$tsc-watch",
"group": {
"kind": "build",
"isDefault": true
- I have tried every variation of the
"cwd"option that I can think of, to no avail. - I have tried changing the
"problemMatcher"configuration to use"fileLocation": "absolute"and"fileLocation": "relative", and neither of these solved the problem. - I have tried manually specifying different options for root and source paths in tsconfig.json, and no matter what I do, TypeScript always reports errors like so (taken from the terminal in vscode):
salix/fantasy/source/client/dom/h.dynamic.ts:66:44 - error TS2345: Argument of type '{ data: (writer: Writer<any, any>) => Lens<any, any>; changes: Stream<unknown[]>; invalidations: Stream<unknown[]>; sync(origin: TimelineOrigin, dtime: number, dpos: number, client: CursorClient<...>): JobInterface; }' is not assignable to parameter of type 'ConnectionDriver<any>'.
How do I get vscode and the TypeScript compiler to agree on where the root path is, or to just get the Typescript compiler to stop including salix/fantasy/ in the path it reports for each error?
EDIT:
I tested manual compilation from the command line, and TypeScript is reporting the paths correctly, which means that for some reason vscode is giving the TypeScript compiler the wrong root path. As a workaround, I have changed my task configuration to the following:
"version": "2.0.0",
"tasks": [
"label": "Server",
"type": "shell",
"command": "cd ${workspaceFolder}; tsc -w",
"isBackground": true,
"options": {
"cwd": "${workspaceFolder}"
"group": {
"kind": "build",
"isDefault": true
This works, but I'd still really like to know why I can't get the standard "typescript" task type to use the correct file location.
