I am currently trying to implement the N-body problem using Euler's method for solving differential equations. However, the graphical outputs do not seem correct, and I'm not sure where the issue in my code is after a while of testing. I'm currently using approximate values for Alpha Centauri A and B to test. This is my code:
import numpy as np
from math import floor
# gravitation constant
G = 6.67430e-11
# astronomical units
au = 1.496e11
sec_in_day = 60 * 60 * 24
dt = 1 * sec_in_day
class Body(object):
def __init__(self, name, init_pos, init_vel, mass):
self.name = name
self.p = init_pos
self.v = init_vel
self.m = mass
def run_sim(bodies, t):
mass = np.array([[b.m] for b in bodies], dtype=float) # (n, 1, 1)
vel = np.array([b.v for b in bodies], dtype=float) # (n, 1, 3)
pos = np.array([b.p for b in bodies], dtype=float) # (n, 1, 3)
names = np.array([b.name for b in bodies], dtype=str)
# save positions and velocities for plotting
plt_pos = np.empty((floor(t/dt), pos.shape[0], pos.shape[1]))
plt_vel = np.empty((floor(t/dt), pos.shape[0], pos.shape[1]))
# center of mass
com_p = np.sum(np.multiply(mass, pos),axis=0) / np.sum(mass,axis=0)
curr = 0
i = 0
while curr < t:
dr = np.nan_to_num(pos[None,:] - pos[:,None])
r3 = np.nan_to_num(np.sum(np.abs(dr)**2, axis=-1)**(0.5)).reshape((pos.shape[0],pos.shape[0],1))
a = G * np.sum((np.nan_to_num(np.divide(dr, r3)) * np.tile(mass,(pos.shape[0],1)).reshape(pos.shape[0],pos.shape[0],1)), axis=1)
pos += vel * dt
plt_pos[i] = pos
vel += a * dt
plt_vel[i] = vel
curr += dt
i += 1
fig = plt.figure(figsize=(15,15))
ax = fig.add_subplot()
for i in list(range(plt_pos.shape[1])):
ax.plot(plt_pos[:,i,0], plt_pos[:,i,1], alpha=0.5, label=names[i])
ax.scatter(plt_pos[-1,i,0], plt_pos[-1,i,1], marker="o", label=f'{i}')
plt.legend()
plt.show()
run_sim(bodies = [ Body('Alpha Centauri A', [0, 0, 0], [0,22345,0], 1.989e30*1.1),
Body('Alpha Centauri B', [23 * au, 0, 0], [0,-18100,0], 1.989e30*0.907),
t = 100 * 365 * sec_in_day
And this is the resulting plot. I would expect their orbits to be less variant and more circular, sort of in a Venn diagram-esque form.
