I am using redigo with connection pool. Below is my code for setting up connection pool and the wrapper for SET call to Redis
//Create a pool of client connections to Redis
func newPool(MaxIdleConns int, Timeout int) *redis.Pool {
return &redis.Pool{
// Maximum number of idle connections in the pool.
MaxIdle: MaxIdleConns*10,
// Close connections after remaining idle for this duration
IdleTimeout: time.Duration(Timeout) * time.Second,
// Maximum number of connections allocated by the pool at a given time.
MaxActive: 500,
// If Wait is true and the pool is at the MaxActive limit, then Get() waits
// for a connection to be returned to the pool before returning.
Wait: true,
// Dial is an application supplied function for creating and
// configuring a connection.
Dial: func() (redis.Conn, error) {
// c, err := redis.DialTimeout("tcp", ":6379", 10*time.Second, 10*time.Second, 10*time.Second)
c, err := redis.Dial("tcp", ":6379")
if err != nil {
fmt.Println("Redis Pool Dial error: ", err)
return c, err
//SET Wrapper
func SET(p *redis.Pool, key string, value []byte) error {
c := p.Get()
defer c.Close()
_, err := c.Do("SET", key, value)
return err
The above code leaks memory.
I am closing the connection properly in defer c.Close().
Surprisingly if I comment out _, err := c.Do("SET", key, value) as in I don't do any c.Do() then the program doesn't leak memory.
