I am using Spring Boot 2.0 and have an endpoint in an @RestController that returns a DeferredResult and in some cases (e.g. if the wanted value does not need to be computed) it sets the result on that DeferredResult directly like so:
@RequestMapping(value = "test")
public DeferredResult<String> test() {
DeferredResult<String> returnValue = new DeferredResult<>();
returnValue.setResult("Hello, World");
return returnValue;
Unfortunately, the HTTP body that is returned is empty. The status code 200 shows that the request did not time out and if I add a completion handler to the deferred result, the handler is also called.
The issue also is not fixed when I explicitly create a new Thread and set the result on that after a small sleep period.
What do I have to change to let the DeferredResult actually be serialised correctly?
Edit:
As suggested in the comments, I turned on debug logging for Spring MVC and found the following log messages:
DEBUG org.springframework.web.servlet.mvc.method.annotation.HttpEntityMethodProcessor - Written [ok] as "text/plain" using [org.springframework.http.converter.StringHttpMessageConverter@6b634d28]
DEBUG org.springframework.web.servlet.DispatcherServlet - Null ModelAndView returned to DispatcherServlet with name 'dispatcherServlet': assuming HandlerAdapter completed request handling
DEBUG org.springframework.web.servlet.DispatcherServlet - Successfully completed request
The result seems to be written correctly at first but then a null ModelAndView is returned to the servlet for some reason.
What could cause this?
