---- Note: working with JavaFX and SQLite ----
Ok guys, first let me illustrate the scenario:
So A has a one-to-many relation with B and C, and the last two have a many-to-many relation between them, as described above.
The sequence of record insertion is such that records in table A are always created first, and when a record in table B is created, at least one record exists in table A. Similarly, when a record in C is created, there will be at least one record in A and one in B.
Here's the question: it's possible that a record being created in C, references multiple records in B, so there will be multiple inserts in table B_C_XRef (dashed circle in picture above), at the same time.
In other words, this is what's happening when a record is created in table C:
- Insert record in C with foreign key from A
- Insert as many records in B_C_XRef as there are references to B
As an example, let's imagine that "C" is an "Orders" table, and "B" is a "Products" table. That way since an order can contain multiple products, how would I add all those records to B_C_XRef representing each order-product relationship?
Thank you in advance.
