Another way, which I believe to be faster (benchmark), is:
def base_2_to_10_array(arr, i1, i2):
res = 0
for bit in arr[i1:i2][::-1]:
res = (res << 1) ^ bit
return res
This is probably faster because it is entirely binary operations (<< and ^), which are both fast (^ is faster because one of the operands is small, being 0 or 1).
percusse's answer is probably slower because of either mapping with str, or casting to int (might not be as optimized for binary).
type_none's is probably slower due to repeated calling of a lambda, multiplication instead of shifts and adding instead of oring.
Example benchmark results:
percusse: 0.016117284998472314
type_none: 0.004335935998824425
pycoder_3rd_fastest: 0.0028656079957727343
pycoder_2nd_fastest: 0.0033370210003340617
pycoder_fastest: 0.0031539250048808753
percusse: 0.13562769599957392
type_none: 0.04904397700011032
pycoder_3rd_fastest: 0.016703221001080237
pycoder_2nd_fastest: 0.021887271002924535
pycoder_fastest: 0.019885091001924593
percusse: 1.358273936995829
type_none: 0.7615448830038076
pycoder_3rd_fastest: 0.18778558799385792
pycoder_2nd_fastest: 0.20695334099582396
pycoder_fastest: 0.18905453699699137
percusse: 14.638380388998485
type_none: 7.554422806002549
pycoder_3rd_fastest: 5.3742733830004
pycoder_2nd_fastest: 2.2020759820006788
pycoder_fastest: 1.9534191700004158
Other attempts, one faster on shorter inputs, can be found in the benchmark link.
