Has anyone had any luck loading script engines into Karaf. I've seen some old links regarding loading script engines into OSGi containers: - https://devnotesblog.wordpress.com/2011/09/07/scripting-using-jsr-223-in-an-osgi-environment/ - Is OSGi fundamentally incompatible with JSR-223 Scripting Language Discovery?
But have had no luck thus far loading into karaf. I have simple example project of what I'm trying to do here:
https://gitlab.com/mkwyche/helpful-hints/tree/master/renjin-karaf
Each time I try to load the script. Using the following line:
ScriptEngineManager manager = new ScriptEngineManager();
// create a Renjin engine:
engine = manager.getEngineByName("Renjin");
// check if the engine has loaded correctly:
if(engine == null) {
throw new RuntimeException("Renjin Script Engine not found on the classpath.");
I get a class not found exception:
at java.lang.Thread.run(Thread.java:745)[:1.8.0_60]Caused by: java.lang.RuntimeException: Renjin Script Engine not found on the classpath. at datadidit.helpful.hints.renjin.karaf.RenjinKarafTest.testRuntime(RenjinKarafTest.java:24) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_60] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_60] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_60] at java.lang.reflect.Method.invoke(Method.java:497)[:1.8.0_60] at org.apache.aries.blueprint.utils.ReflectionUtils.invoke(ReflectionUtils.java:299)[12:org.apache.aries.blueprint.core:1.6.2] at org.apache.aries.blueprint.container.BeanRecipe.invoke(BeanRecipe.java:980)[12:org.apache.aries.blueprint.core:1.6.2] at org.apache.aries.blueprint.container.BeanRecipe.runBeanProcInit(BeanRecipe.java:736)[12:org.apache.aries.blueprint.core:1.6.2] ... 40 more
I've tried embedding bundles, dynamic-imports, etc... Any suggestions would be greatly appreciated.
Thanks.
