This can be seen by induction.
Suppose, xs == []. Both expressions are true, since both yield error.
Suppose, xs == [y]
maximum([y]++map(x+)[y]) == -- by definition of map
== maximum([y]++[x+y])
-- by definition of ++
== maximum([y,x+y])
-- by definition of maximum
== foldr1 max [y,x+y]
-- by definition of foldr1
== max y (foldr1 max [x+y])
== max y (x+y)
-- by definition of foldr1 and maximum [y]
== max (maximum [y]) (x+maximum [y])
Next, we will need a proof of commutativity of maximum: maximum (xs++(y:ys)) == max y (maximum (xs++ys)) - you will notice this is needed, if you skip this proof and go straight to the proof of maximum (y:ys ++ map(x+)(y:ys)) - one step there requires to move (x+y) from the middle of the list ys++(x+y):map(x+)ys.
Suppose, xs==[]:
maximum ([]++(y:ys)) == maximum (y:ys)
== max y (maximum ys)
== max y (maximum ([]++ys))
Suppose, xs==x:xx:
maximum(x:xx++(y:ys)) == maximum (x:(xx++(y:ys)))
== max x (maximum (xx++(y:ys)))
-- by induction
== max x (max y (maximum (xx++ys)))
-- by commutativity of max, max a (max b c) == max b (max a c)
== max y (max x (maximum (xx++ys)))
== max y (maximum (x:(xx++ys)))
== max y (maximum ((x:xx) ++ ys))
Ok, now get back to proving the original statement.
Now, suppose xs == y:ys
maximum (y:ys ++ map(x+)(y:ys)) ==
== maximum(y:ys ++ (x+y):map(x+)ys)
== max y (maximum(ys ++ (x+y):map(x+)ys)
-- by commutativity of maximum
== max y (max (x+y) (maximum (ys++map(x+)ys)))
-- by induction, (maximum (ys++map(x+)ys)) == max (maximum ys) (x+maximum ys))
== max y (max (x+y)
(max (maximum ys) (x+maximum ys)))
-- by commutativity of max (ie max a (max b c) == max b (max a c))
== max y (max (maximum ys)
(max (x+y) (x+maximum ys)))
-- by associativity of max (is max a (max b c) == max (max a b) c)
== max (max y (maximum ys))
-- by definition of max, max (x+y) (x+z) == x+(max y z)
(x + max y (maximum ys)))
== max (maximum (y:ys)) (x + maximum (y:ys))
Since you asked also about induction and how to see a certain thing can be proven by induction, here's some more.
You can see some of the steps are "by definition" - we know they are true by looking at how the function is written. For example, maximum = foldr1 max and foldr1 f (x:xs) = f x $ foldr1 f xs for non-empty xs. Definition of some other things are less clear - max y z the definition of max is not shown; yet, it can be shown by induction that max (x+y)(x+z) == x+max y z. Here one would start with the definition of max 0 y == y, then how to work out max for greater x. (Then you'd also need to cover the cases for negative x and y in a similar way.)
For example, natural numbers are zero and any successor of a natural number. You see, here we don't have any comparison defined, nothing. So, the properties of addition, subtraction, max, etc, stem from the definition of the functions:
data Nat = Z | S Nat -- zero and any successor of a natural number
(+) :: Nat -> Nat -> Nat -- addition is...
Z + x = x -- adding zero is neutral
(S x) + y = S (x + y) -- recursive definition of (1+x)+y = 1+(x+y)
-- here unwittingly we introduced associativity of addition:
-- (x+y)+z=x+(y+z)
-- so, let's see the simplest case:
-- x == Z
-- (Z+y)+z == -- by definition, Z+y=y -- see the first line of (+)
-- == y+z
-- == Z+(y+z) -- by definition, Z+(y+z)=(y+z)
-- ok, now try x == S m
-- (S m + y) + z == -- by definition, (S m)+y=S(m+y) -- see the second line of(+)
-- == S (m+y) + z
-- == S ((m+y)+z) -- see the second line of (+)
-- - S (m+y) + z = S ((m+y)+z)
-- == S (m+(y+z)) -- by induction, the simpler
-- case of (m+y)+z=m+(y+z)
-- is known to be true
-- == (S m)+(y+z) -- by definition, see second line of (+)
-- proven
Then, because we don't have comparison of Nats yet, have to define max in a particular way.
max :: Nat -> Nat -> Nat
max Z y = y -- we know Z is not the max
max x Z = x -- and the other way around, too
-- this inadvertently introduced commutativity of max already
max (S x) (S y) = S (max x y) -- this inadvertently introduces the law
-- that max (x+y) (x+z) == x + (max y z)
Suppose, we want to prove the latter.
Assume x == Z
max (Z+y) (Z+z) == -- by definition of (+)
== max y z
== Z + (max y z) -- by definition of (+)
ok, now assume x == S m
max ((S m) + y) ((S m)+z) == -- by definition of (+)
== max (S(m+y)) (S(m+z))
== S (max (m+y) (m+z))
-- by induction
== S (m+(max y z))
== (S m)+(max y z)
So, you see, it is important to know the definitions, important to prove the simplest case, and important to use the proof for the simpler case in the slightly more complex case.
