Well, I can immediately say that there is nothing special about the second method:
class my_class():
content...
In the above code, the parenthesis are redundant and do not affect the class definition at all. The reason why Python allows you to have them is explained by @chepner's comment. Basically, because the list of base classes (the code placed inside the parenthesis) may be any valid expression, () is allowed because it is syntactically valid.
The purpose of the other two methods depends on what version of Python you are using.
Python 2.x
The following code will create an old-style or classic class:
class my_class:
content...
In Python versions before 2.2, old-style classes were the only type of classes available. According to Python's documentation on them:
The concept of (old-style) class is unrelated to the concept
of type: if x is an instance of an old-style class, then x.__class__
designates the class of x, but type(x) is always <type 'instance'>.
This reflects the fact that all old-style instances, independently of
their class, are implemented with a single built-in type, called
instance.
However, in Python versions 2.2 or greater, this all changes if you inherit from the object built-in:
class my_class(object):
content...
Now, you will be creating a new-style class, which has an entirely different object model. Unlike its predecessor, a new-style class:
...is neither more nor less than a user-defined type. If x is an instance
of a new-style class, then type(x) is typically the same as
x.__class__...
If you would like some more information on what the differences between old-style and new-style classes are, see this great SO question which asks exactly that.
Python 3.x
In Python 3.x, all classes implicitly inherit from object and are thus new-style classes.
This means that it is now redundant to do:
content...
because doing this:
class my_class:
content...
will yield the same results. However, many programmers still explicitly inherit from object to make their classes backwards-compatible with older versions of Python.
