EDIT: I mistakenly use the term Stealth Address when referring to a Monero Wallet Subaddress. Please, be aware.
I'm aware that "bare" Monero addresses aren't used to perform calculations. But after trying to learn how to calculate a Transaction Public Key I stumbled with this formula:
R = r G
Then I noticed that when dealing with Stealth Addresses, this latter is used instead of G:
R = r Si
I understand that r must be a random scalar that had to be previously normalized/reduced in order to work with EC calculations. i.e., ensuring that the scalar isn't larger than 32 bytes (256 bits).
This is where my doubts start:
When decoding a Stealth Address: 8AQnEcUWadV8VDJnH9b6CJ2DUXn1A9bSpdNQyq6rCvr6T9ysPkSH9u9DDYundxN2rDHbx2KCXu2ioQifx9a1qBZh64CCsPz
into bytes, I get this:
[42, 209, 251, 118, 80, 62, 204, 192, 44, 194, 36, 10, 52, 244, 171, 211, 7, 67, 181, 180, 77, 84, 182, 177, 217, 111, 237, 232, 101, 182, 176, 123, 156, 94, 154, 187, 85, 57, 70, 96, 73, 9, 119, 96, 117, 37, 152, 194, 99, 66, 159, 22, 164, 240, 226, 124, 141, 205, 178, 20, 54, 250, 91, 112, 44, 206, 71, 37, 197]
As we can notice, we are dealing with 69 bytes, or 552 bits.
How am I supposed to calculate r * Si, if r is 32 bytes long and Si is 69 bytes long?
Should I normalize/reduce the Stealth Address before performing the calculation? i.e., r * reduce_32(Si)?
Hopefully one of you guys can give me a hand with this.
3af2
  • 63
How Elliptic Curve calculations are possible when using base58 addresses, if these are 552 bits long?
An address is encoded (ref):
The address is actually the concatenation, in Base58 format, of the public spend key and the public view key, prefixed with the network byte (the number 18 for Monero) and suffixed with the first four bytes of the Keccac-256 hash of the whole string (used as a checksum).
Thus one has to extract the relevant public keys.
But after trying to learn how to calculate a Transaction Public Key I stumbled with this formula: R = r G
That is the formula for the transaction public key, yes.
Then I noticed that when dealing with Stealth Addresses, this latter is used instead of G: R = r Si
A stealth address (better known as a one-time output key), is actually created:
Hs(8rA|i)G+B
Here r is the sender generated random private key, A and B the recipient's public view and spend keys respectively, Hs hash-to-scalar and i the output index.
No, r must be reduced mod l (the curve order) to be a valid private key / scalar.
A stealth address (better known as a one-time output key) is not 69 bytes / 552 bits. It's a 32 byte (256 bit) public key.
That is not a stealth-address. It's a wallet subaddress.
jtgrassie
  • 19,601
  • 17
  • 54
