I want to create python module with C++ bindings of monero functions:
- parse_and_validate_block_from_blob
- get_block_hashing_blob
- rx_slow_hash
- and more...
I'm using ubuntu 18.04. For the simplicity of this question, I removed the code associated with creating of python module using pybind11.
I cloned the monero repository. I installed all dependencies following this instruction. Then, I run following commands to build static libs which I need:
$ cmake .
$ make cryptonote_basic
And I want to compile simple target pymonero.cpp (full):
#include <iostream>
#include "cryptonote_basic/cryptonote_format_utils.h"
using namespace cryptonote;
using namespace std;
int main() {
blobdata b_blob = h2b("0c0ce185b0f2053941deed208d6449bb432fbce9778efb4cd9229cc79e4c04ef7b2a2f7c99df4a0000000002afdd1f01fff3dc1f018f918980888803025b08e22c6cb11c61b628de4217c3959627414d2d10579b780ca1e1fec0164bba210174b9819eb50c698d574bc408a0f7fedd608296647291551e98be4f7134bc26660000");
blobdata hashing_blob;
cout << "Input:\t" << string_to_hex(b_blob) << endl;
block b = AUTO_VAL_INIT(b);
if (!parse_and_validate_block_from_blob(b_blob, b)) {
cout << "Not valid blob" << endl;
return -1;
hashing_blob = get_block_hashing_blob(b);
cout << "Output:\t" << string_to_hex(hashing_blob) << endl;
return 0;
I'm trying to build this target with following commands:
echo "Building CXX object"
/usr/bin/c++ \
-I$MONERO_DIR/src \
-I$MONERO_DIR/contrib/epee/include \
-I$MONERO_DIR/external/easylogging++ \
-o _build/pymonero.cpp.o \
-c pymonero.cpp
echo "Linking CXX executable pymonero"
/usr/bin/c++ _build/pymonero.cpp.o -o pymonero \
-L$MONERO_DIR/src -lversion \
-L$MONERO_DIR/src/cryptonote_basic -lcryptonote_basic \
-L$MONERO_DIR/src/device -ldevice \
-L$MONERO_DIR/src/ringct -lringct_basic \
-L$MONERO_DIR/src/common -lcommon \
-L$MONERO_DIR/src/crypto -lcncrypto \
-L$MONERO_DIR/contrib/epee/src -lepee \
-L$MONERO_DIR/external/easylogging++ -leasylogging \
-L$MONERO_DIR/external/randomx -lrandomx \
-L$MONERO_DIR/external/miniupnp \
/usr/lib/x86_64-linux-gnu/libboost_thread.so \
/usr/lib/x86_64-linux-gnu/libboost_chrono.so \
/usr/lib/x86_64-linux-gnu/libboost_system.so \
/usr/lib/x86_64-linux-gnu/libboost_filesystem.so \
/usr/lib/x86_64-linux-gnu/libboost_regex.so \
/usr/lib/x86_64-linux-gnu/libssl.so \
/usr/lib/x86_64-linux-gnu/libcrypto.so \
/usr/lib/x86_64-linux-gnu/libhidapi-libusb.so \
/usr/lib/x86_64-linux-gnu/libsodium.so \
/usr/lib/x86_64-linux-gnu/libunbound.so \
-lpthread -ldl
$MONERO_DIR is path to the cloned monero repository.
Output of last command give me following error:
./monero//src/device/libdevice.a(device_ledger.cpp.o): In function `hw::ledger::device_ledger::reset()':
device_ledger.cpp:(.text+0x4a52): undefined reference to `MONERO_VERSION'
collect2: error: ld returned 1 exit status
I tried to build this target on ubuntu 16.04 and again got this error. I don’t know if I did it right that I came here with a question about compilation of C++ sources. But I am very tired and feel that here is some kind of simple inattentive mistake.
