I am not able to find a solution to this problem. Finding the limit
$$\lim_{n\to\infty} \left( \sum_{k=1}^{n} \frac{1}{\binom{n}{k} } \right)^n$$
I have tried using Mathematica, and that numerically evaluates it to $7.3890560989 \cdots$
Which motivates me to think it is $e^2$. Thanks for help
The largest summands are $\frac1{n\choose n}+\frac1{n\choose n-1}+\frac1{n\choose 1}=1+\frac2n$. The next smallest are $\frac1{n\choose n-2}=\frac1{n\choose 2}=\frac2{n(n-1)}=O(n^{-2})$, the others are $\le \frac1{n\choose 3}=\frac6{n(n-1)(n-2)}$. Since there are $n-4$ of these summands, their total is $\le \frac{6(n-4)}{n(n-1)(n-2)}=O(n^{-2})$. Hence the sum in parentheses is $1+\frac2n+O(n^{-2})$. As $\lim_{n\to\infty}(1+\frac xn)^n=e^x$, your guess was right, the limit is $e^2$.
$$\left(\sum_{k=1}^{n} \frac{1}{\binom{n}{k}}\right )^n=e^{n\log\sum\limits_{k=1}^{n} \frac{1}{\binom{n}{k}}}.$$ $$\binom{n}{1}=\binom{n}{n-1}=n,\binom{n}{2}=\binom{n}{n-2}=\frac{n(n-1)}{2},\binom{n}{2}\leq\binom{n}{k}, \ k=2,\cdots,n-2,$$ $$\sum_{k=1}^{n-1}\frac{1}{\binom{n}{k}}=\frac{2}{n}+\sum_{k=2}^{n-2}\frac{1}{\binom{n}{k}}<\frac{2}{n}+\frac{n-3}{\binom{n}{2}}\ \to0\ (n\to\infty).$$
$$n\log\sum\limits_{k=1}^{n} \frac{1}{\binom{n}{k}}=n\log\left(1+\sum\limits_{k=1}^{n-1}\frac{1}{\binom{n}{k}}\right) \sim n\cdot\sum\limits_{k=1}^{n-1} \frac{1}{\binom{n}{k}}.$$ So $$\frac{n}{\binom{n}{2}}=\frac{n}{\binom{n}{n-2}}\to0,\ n\cdot\sum\limits_{k=3}^{n-3} \frac{1}{\binom{n}{k}}\leq\frac{n(n-5)}{\binom{n}{3}}\to 0\ (n\to\infty),$$ $$n\cdot\sum\limits_{k=1}^{n-1} \frac{1}{\binom{n}{k}}\to 2\ (n\to\infty).$$ $$\left(\sum_{k=1}^{n} \frac{1}{\binom{n}{k}}\right )^n=e^{n\log\sum\limits_{k=1}^{n} \frac{1}{\binom{n}{k}}}\to e^2\ (n\to\infty).$$
Riemann
  • 11,801
Using the following previous results we have that
$\sum_{k=0}^n\frac1{\binom{n}{k}}=\frac{n+1}{2^{n+1}}\sum_{k=1}^{n+1}\frac{2^k}{k} \implies \sum_{k=1}^n\frac1{\binom{n}{k}}=\frac{n+1}{2^{n+1}}\sum_{k=1}^{n+1}\frac{2^k}{k}-1\tag{1}$
$$\sum_{k=1}^{n+1}\frac{2^k}{k} = \frac{2^{n+2}}{n+1}+\frac{2^{n+2}}{(n+1)^2}+O\left(\frac1n\right) \tag 2$$
therefore
$$ \sum_{k=1}^{n} \frac{1}{\binom{n}{k} } = 1+\frac2{n+1}+O\left(\frac1{2^n}\right)$$
and therefore
$$\left( \sum_{k=1}^{n} \frac{1}{\binom{n}{k} } \right)^n = \left(1+\frac2{n+1}+O\left(\frac1{2^n}\right) \right)^n \to e^2$$
user
  • 162,563
