Starting with a certain geometric problem, I have reached this function:
$$R(s,t,u,v)=\max(s-u,s+u,t-v,t+v,sX+tY+u, tX-sY+v)$$
where $X\geq0$ and $Y\geq0$ are parameters.
I have to find the minimum possible value of $R$ given the paramters, i.e.:
$$\min_{s,t,u,v}R(s,t,u,v) $$
with the given constraints:
$$s\geq 0$$ $$t\geq 0$$ $$s^2+t^2=1$$
How do I approach this problem? How do I approach such min-max problems in general?
EDIT: While I still don't have a general solution, I have made some progress with this particular problem in a particular case: the case in which $u\geq 0$ and $v\geq 0$.
In this case, we can drop the terms $s-u$ and $t-v$ from $R$. Additionally, because $u$ and $v$ are unrelated, we can write $R$ as follows:
$$R(s,t,u,v)=\max( u+\max(s,sX+tY), v+max(t,tX-sY))$$
Now it is clear that, regardless of $s$ and $t$, in order to minimize $R$ we must take $u=v=0$. This gives:
$$R(s,t)=\max(s,sX+tY, t,tX-sY)$$
I.e. the function to minimize is now a function of only 2 variables.
My questions now are:
  • Is this simplification process valid?
  • Does it generalize to other similar problems, or is it only a lucky coincidence that works only in this particular problem?
Calling it a min-max problems sends the wrong signal, as that typically is reserved for a different type of problems. You have a standard optimization problem, albeit with a non-smooth objective. It can trivially be cast as a problem without any max-operator though by introducing a new variable to upper-bound the element in the max
$$\min_{z,s,t,u,v} z$$ $$z\geq s-u,z\geq s+u,z\geq t-v,z\geq t+v,z\geq sX+tY+u, z\geq tX-sY+v$$ $$s\geq 0,t\geq 0,s^2+t^2=1$$
Your real problem though is the fact that you have a nonconvex constraint on $s$ and $t$.
What is the underlying geometric problem?
Johan Löfberg
  • 9,737
  • 16
  • 15
  • The general geometric problem is this: http://math.stackexchange.com/questions/851185/how-fat-is-a-triangle Although there are other solutions, I still want to know how to solve optimization problems such as this. It seems a useful feat to have :) – Erel Segal-Halevi Oct 04 '14 at 21:20
