This is a two part question
Given $\gcd(a,b) = 1$
consider $$\gcd \left( \frac{a^n - b^n }{a-b}, a- b\right) $$
It appears that the value of this is always equal to $n$ or $1$. How to prove it?
And with that show
$$\gcd \left( \frac{a^n - b^n }{a-b}, a- b\right) = \gcd \left( n \frac{a^{n-1} - b^{n-1}}{a-b}, a- b \right) $$
I began with tackling the first part
I trie to use an Inductive Proof at first by noting:
$$\frac{a^{n+1} - b^{n+1}}{a-b} = a\frac{a^{n} - b^{n}}{a-b} + b^{n} = b\frac{a^{n} - b^{n}}{a-b} + a^{n} $$
But this didn't pan out any sort of solution since it doesn't become immediately apparent that $n+1$ divides this new quantity or some linear combination of this quantity with $a - b$
I could attempt a combinatorial approach and ty to use the binomial theorem I was thinking. But no apparent way to match terms become apparent.
What should I do for the first part?
Hint $\,\ \big(x\!-\!a,\frac{f(x)-f(a)}{x-a}\!\big) = (x\!-\!a,\:f'(a))\,\ $ by $\ \frac{f(x)-f(a)}{x-a} \equiv f'(a)\pmod{\!x\!-\!a}\ $ for $\ f(x)\in \mathbb Z[x]$
For further details see my post here, which elaborates on how this result is a number-theoretical analog of a well-known result about functions (polynomials), viz. about multiplicity of roots.
Bill Dubuque
  • 282,220
  • I think this is probably far more advanced than what I was expected to use, but damn... thats a very interesting identity there. I don't think I've seen calculus and number theory intersect that curiously before – Sidharth Ghoshal Aug 05 '14 at 17:25
  • @frogeyedpeas It uses only an infinitesimal amount of calculus, viz. differentiation of polynomials, which can actually be defined purely algebraically by the above congruence. – Bill Dubuque Aug 05 '14 at 17:26
If $D$ is the GCD, then $a\equiv b\pmod D$, and therefore:
$$0\equiv \frac{a^n-b^n}{a-b} = \sum_{k=0}^{n-1} a^kb^{n-1-k} \equiv \sum_{k=0}^{n-1} a^{n-1} = na^{n-1}\pmod D$$
So $D\mid na^{n-1}$. Since $D\mid a-b$ and $(a-b,a)=1$, you have: $$D\mid n$$
On the other hand, it is easy to show the converse, that if $d\mid a-b$ and $d\mid n$ then $d\mid \frac{a^n-b^n}{a-b}$.
So $D=\gcd(n,a-b)$.
Thomas Andrews
  • 186,215
