In some sense (I think), you have, in your question, enough information to adequately answer it yourself. When you wrote me (in response to my question as to what deeper knowledge you were seeking regarding Whitehead's problem), "why is it not possible to check if the group is Whitehead in ZFC", I am going to infer that "the group" you had in mind is the group you spoke about in your question, the "group of cardinality $\aleph_1$ that satisfies Chase's condition, and is not free" that is "Whitehead when we add Martin's axiom" (and $2^{\aleph_0}$ $\gt$ $\aleph_1$) and "is not Whitehead when we add V=L" to ZFC.
To show that you have, in fact, answered your own question, I would like to present a mathematical 'thought experiment' regarding the aforementioned group. The gist of the experiment is to use the following theorem, due to Solovay and Tennenbaum
Assume GCH [in V, the 'universe' formed by the 'cumulative hierarchy'--my comment] and let $\kappa$ be a regular cardinal greater than $\aleph_1$. There exists a c.c.c. notion of forcing P such that the generic extension V[G] by P satisfies Martin's Axiom and $2^{\aleph_0}$=$\kappa$
to relate the domain of sets in which ZF+V=L holds to the domain of sets in which ZFC+Martin's Axiom+$2^{\aleph_0}$ $\gt$$\aleph_1$ holds. That this theorem does is clear by the fact that ZF+V=L $\vdash$GCH so that the domain of sets in which ZFC+Martin's axiom +$2^{\aleph_0}$ $\gt$$\aleph_1$ is a forcing extension of the domain of sets in which ZF+V=L holds, both domains via the c.c.c. having the same cardinals and cofinalities.
Now according to your question, the group of cardinality $\aleph_1$ which is not free and satisfies Chase's condition, is not Whitehead in the domain of sets in which ZFC+V=L holds. Since this is a domain in which ZFC holds, by constructing this group in ZFC+V=L, you 'checked' that his group is not Whitehead in this domain (it should be noted that in the Eklof paper you mention in your question the construction of the group A of cardinality $\aleph_1$ satisfying Chase's condition but was not free was carried out entirely in ZFC). Now by the theorem of Solovay and Tennenbaum one can use the notion of forcing P (which satisfies the c.c.c.) to construct from the domain of sets which satisfies ZFC+V=L the domain of sets satisfying ZFC+Martin's Axiom +$2^{\aleph_0}$ $\gt$ $\aleph_1$ and since Goedel proved that L is a subdomain of sets in ZFC (actually ZF) in which not only the axioms of ZF hold but AC and GCH hold as well, one might rightfully infer that the domain of sets in which ZFC+Martin's Axiom +$2^{\aleph_0}$ $\gt$ $\aleph_1$ exists as well and reconstruct the group A in this domain so it is Whitehead--by construction you have checked that A is Whitehead within this domain in which ZFC holds. This shows that it is impossible to check whether the group A you speak about in your question is or is not Whitehead in ZFC because ZFC in itself does not contain sufficient information (i.e. the extra axioms, by the 'facts' each of the domains prove about the group A, the axioms are incompatible) to decide the question.
