18
How can one prove the following identity of the cross product?
$$(M a)\times (M b)=\det(M) (M^{\rm T})^{-1}(a\times b)$$
$a$ and $b$ are 3-vectors, and $M$ is an invertible real $3 \times 3$ matrix.
Widawensen
  • 8,517
stst
  • 183
  • I would think that this formula follows from the relation between the cross product and the wedge product in the exterior algebra $\bigwedge(\Bbb{R}^3)$. The exterior algebra construction is functorial. My first guess would be that if you check out that relation, this identity pops out. – Jyrki Lahtonen Jul 08 '14 at 07:36
    If you want the gory details from the exterior algebra perspective, you can take a look at the addendum to my answer here http://math.stackexchange.com/a/752800/49610 However, the accepted answer really goes to the heart of the matter. – Branimir Ćaćić Jul 08 '14 at 23:12
    Nice, @Branimir! I also agree with your assessment of the accepted answer. – Jyrki Lahtonen Jul 09 '14 at 07:23
4 Answers4
17
Recall that $u\times v$ is the only vector $w\in\mathbb{R}^3$ that satisfies $$\forall\, x\in\mathbb{R}^3,\quad \det(u,v,x)=\langle w,x\rangle$$ So, we have $$\eqalign{\det(M)\langle a\times b,x\rangle&= \det(M)\det(a,b,x)\cr&=\det(Ma,Mb,Mx)\cr &=\langle Ma\times Mb,Mx\rangle\cr &=\langle M^T(Ma\times Mb),x\rangle\cr } $$ Thus $$\forall\, x\in\mathbb{R}^3,\quad \langle\det(M)( a\times b),x\rangle=\langle M^T(Ma\times Mb),x\rangle$$ It follows that $\det(M)( a\times b)=M^T(Ma\times Mb)$ or equivalently, for an invertible matrix $M$, $$\det(M)(M^T)^{-1}( a\times b)= Ma\times Mb $$
Remark. The most general formula is $${\rm Co}(M)( a\times b)= Ma\times Mb$$ where ${\rm Co}(M)$ is the matrix of cofactors of $M$. Here we do not need $M$ to be invertible. This follows from the proved formula by continuity.
Omran Kouba
  • 29,112
Building on Jyrki's comment, the relationship between the wedge and cross products is of some interest here.
This is most easily formulated using clifford algebra, instead of just exterior algebra. In clifford algebra, the cross product and the wedge product of vectors are related through duality:
$$a \times b = -i (a \wedge b)$$
Multiplication by the pseudoscalar $i$ performs the duality operation.
The extension of linear operators, which are represented by matrices, to multivectors is simplest when viewed in terms of the wedge product:
$$M(a \wedge b) \equiv M(a) \wedge M(b)$$
This extends to any number of wedges, so Omran's proof using clifford algebra would look something like this:
$$(\det M)(a \wedge b \wedge x) = M(a \wedge b \wedge x) = [M(a) \wedge M(b)] \wedge M(x) = -i [M(a) \times M(b)] \cdot M(x) = \ldots$$
A more direct approach, albeit more difficult to prove first principles, is to use to following inverse formula:
$$[M^T]^{-1}(a) = [M(i)]^{-1} M(i a) $$
Given that $i (a \times b) = a \wedge b$, we get the result
$$[M^T]^{-1}(a \times b) = (\det M)^{-1} i^{-1} M(a \wedge b) = (\det M)^{-1} M(a) \times M(b)$$
Muphrid
  • 20,661
An elementary proof:
Let $\mathbf{a} = (a_1, a_2, a_3)^T$ and $\mathbf{b} = (b_1, b_2, b_3)^T$.
Then $\mathbf{a} \times \mathbf{b} = (a_2 b_3 - a3 b_2, a_3 b_1 - a_1 b_3, a_1 b_2 - a_2 b_1)^T$.
Let $M = \begin{pmatrix} a_{11} & a_{12} & a_{13} \\ a_{21} & a_{22} & a_{23} \\ a_{31} & a_{32} & a_{33} \end{pmatrix}$. Also let $\mathbf{m}_1$, $\mathbf{m}_2$ and $\mathbf{m}_3$ be the three columns of $M$.
Now $M\mathbf{a} = a_1 \mathbf{m}_1 + a_2 \mathbf{m}_2 + a_3 \mathbf{m}_3$ and $M\mathbf{b} = b_1 \mathbf{m}_1 + b_2 \mathbf{m}_2 + b_3 \mathbf{m}_3$. So we have: $$ \begin{align} (M\mathbf{a})\times (M\mathbf{b}) &= (a_1 \mathbf{m}_1 + a_2 \mathbf{m}_2 + a_3 \mathbf{m}_3) \times (b_1 \mathbf{m}_1 + b_2 \mathbf{m}_2 + b_3 \mathbf{m}_3)\\ &= a_1 b_1 \mathbf{m}_1 \times \mathbf{m}_1 + a_1 b_2 \mathbf{m}_1 \times \mathbf{m}_2 + a_1b_3 \mathbf{m}_1 \times \mathbf{m}_3 \\ &\quad+ a_2 b_1 \mathbf{m}_2 \times \mathbf{m}_1 + a_2 b_2 \mathbf{m}_2 \times \mathbf{m}_2 + a_2b_3\mathbf{m}_2 \times \mathbf{m}_3\\ &\quad+ a_3 b_1 \mathbf{m}_3 \times \mathbf{m}_1 + a_3 b_2 \mathbf{m}_3 \times \mathbf{m}_2 + a_3 b_3\mathbf{m}_3 \times \mathbf{m}_3\\ &= \mathbf{0} + a_1 b_2 \mathbf{m}_1 \times \mathbf{m}_2 - a_1b_3 \mathbf{m}_3 \times \mathbf{m}_1 \\ &\quad- a_2 b_1 \mathbf{m}_1 \times \mathbf{m}_2 + \mathbf{0} + a_2b_3\mathbf{m}_2 \times \mathbf{m}_3\\ &\quad+ a_3 b_1 \mathbf{m}_3 \times \mathbf{m}_1 - a_3 b_2 \mathbf{m}_2 \times \mathbf{m}_3 + \mathbf{0}\\ &= (a_2 b_3 - a_3 b_2) \mathbf{m}_2 \times \mathbf{m}_3 + (a_3b_1 - a_1b_3)\mathbf{m}_3 \times \mathbf{m}_1 + (a_1 b_2 - a_2 b_1)\mathbf{m}_1 \times \mathbf{m}_2\\ &= [\mathbf{m}_2 \times \mathbf{m}_3 | \mathbf{m}_3 \times \mathbf{m}_1 | \mathbf{m}_1 \times \mathbf{m}_3 ] (\mathbf{a} \times \mathbf{b})^T \end{align} $$
Now $$ \begin{align} \mathbf{m}_2 \times \mathbf{m}_3 &= (m_{12}, m_{22}, m_{32})^T \times (m_{13}, m_{23}, m_{33})^T \\ &= (m_{22}m_{33} - m_{32}m_{23}, m_{32}m_{13} -m_{12}m_{33}, m_{12} m_{23} - m_{13}m_{22})^T \end{align} $$ Note that if $M_{ij}$ is the determinant of the matrix obtained by removing row $i$ and column $j$ of $M$, then this vector is $(M_{11}, -M_{21}, M_{31})^T$. That is, it is the first column of the matrix of cofactors of $M$. Similarly, the other two cross products of columns of $M$ produce the other two columns of the matrix of cofactors of $M$.
Denote the matrix of cofactors of $M$ by $\mathrm{Co}(M)$ and then we have: $$ (M\mathbf{a})\times(M\mathbf{b}) = \mathrm{Co}(M) (\mathbf{a} \times \mathbf{b}) $$
Note that the adjugate of $M$, $\mathrm{adj} M$ is the transpose of $\mathrm{Co}(M)$ and has the property that $\mathrm{adj}(M) M = M \mathrm{adj}(M) = \det(M) I$. If $M$ is invertible then $$ M^{-1} = \frac{1}{\det(M)}\mathrm{adj} M = \frac{1}{\det(M)} (\mathrm{Co}(M))^T\\ (M^{-1})^T = \frac{1}{\det(M)} \mathrm{Co}(M)\\ \det(M) (M^{-1})^T = \mathrm{Co}(M) $$ Hence if $M$ is invertible we have $$ (M\mathbf{a})\times(M\mathbf{b}) = \mathrm{Co}(M) (\mathbf{a} \times \mathbf{b}) = \det(M) (M^{-1})^T) (\mathbf{a} \times \mathbf{b}) $$
DavidButlerUofA
  • 3,414
  • 18
  • 24
A summation convention proof: we start from
If $M$ is a $3 \times 3$ matrix, $$ [\operatorname{adj}{M}]_{ij} = \frac{1}{2} \epsilon_{ikl} \epsilon_{jmn} M_{km}M_{ln} . $$
which is straighforward to verify by multiplying by $M_{jp}$. The proof of $(1)$ then simply involves multiplying by $\epsilon_{jpq}a_p b_q$ and using the $\epsilon\epsilon=\delta\delta-\delta\delta$ identity: $$ \begin{align} [(\operatorname{adj}{M})(a \times b)]_i &= \frac{1}{2} \epsilon_{ikl} \epsilon_{jmn} M_{km}M_{ln} \epsilon_{jpq} a_p b_q \\ &= \frac{1}{2} \epsilon_{ikl} ( \delta_{mp}\delta_{nq} - \delta_{mq}\delta_{np} ) M_{km}M_{ln} a_p b_q \\ &= \frac{1}{2} \epsilon_{ikl} ( M_{km} a_m M_{ln} b_n - M_{km} b_n M_{ln} a_n ) \\ &= \epsilon_{ikl} [Ma]_k [Ma]_l = [(Ma) \times (Mb)]_i \end{align} $$
Chappers
  • 69,099
