Which of the following cannot be written as the intersection of countably many open sets in $\mathbb R$?
  1. $\mathbb Z$
  2. $\mathbb Z'$
  3. $\mathbb Q$
  4. $\mathbb Q'$
  5. $[0,1)$
My attempt: I know that the sets $\mathbb Z',\mathbb Q',[0,1)$ are $G_\delta$ and $\mathbb Q$ is not $G_\delta$ and because $\mathbb Z$ is closed in $\mathbb R$ so it is $F_\sigma$, not $G_\delta$.
Am I right?
Nannes
  • 1,151
  • 19
  • What does the $'$ mean? – bof Jun 11 '14 at 10:48
  • Q' means complement of Q in R, similarly Z' is the complement of Z in R – Nannes Jun 11 '14 at 10:55
  • Where you wrote $F_\delta$ I guess you meant $F_\sigma$, because $F_\delta=F$. Anyway, $\mathbb Z$ is $G_\delta$, because closed sets in $\mathbb R$ are $G_\delta$. You're right that $\mathbb Q$ is not $G_\delta$ (it is $F_\sigma$), and $[0,1)$ is both $G_\delta$ and $F_\sigma$. I don't know what you mean by $\mathbb Z'$ and $\mathbb Q'$. – bof Jun 11 '14 at 10:55
  • OK, then you're right about $\mathbb Z'$ and $\mathbb Q'$ being $G_\delta$. – bof Jun 11 '14 at 10:58
  • But you said that Z is G delta because it is closed, is this a theorem? Can you tell me some book from which i find this result? – Nannes Jun 11 '14 at 11:00
  • $U_n=\bigcup_{z\in\mathbb Z}(z-\frac1n,z+\frac1n)$ is open, so $\mathbb Z=\bigcap_{n=1}^\infty U_n$ is $G_\delta$. The more general result, that every closed set is $G_\delta$, is proved in a similar way. It's not true in all topological spaces, but it is true in all metric spaces. I'll try and find an online reference for you. – bof Jun 11 '14 at 11:08
  • Ok now i understand,thank you very much. – Nannes Jun 11 '14 at 11:10
  • You're welcome. Also see this old question. – bof Jun 11 '14 at 11:12
  • Thank you for the reference. – Nannes Jun 11 '14 at 11:16
$\mathbb{Z}$ is closed in a metric space so a $G_\delta$. To see this define for a set $A \subset X, r>0$: $B(A,r) = \{y \in X: d(y, A) < r \}$, show this is open, and show that $\overline{A} = \cap_{n \in \mathbb{N}} B(A, \frac{1}{n})$, so when $A$ is closed, we have written it as an intersection of countably many open sets.
Of course, this is overkill in general (but nice to know), and we can just define $U_n = \cup_{a \in \mathbb{Z}} (a - \frac{1}{n}, a+\frac{1}{n})$, which is open as a union of open sets, and show that $\cap U_n = \mathbb{Z}$ (same idea of course).
$\mathbb{Z}'$ is open, so certainly a $G_\delta$.
$\mathbb{Q}$ is not a $G_\delta$ by the Baire category theorem.
$\mathbb{Q}' = \cap_{q \in \mathbb{Q}} \{q\}'$, which is a $G_\delta$ as the rationals are countable, and complements of singletons are open.
$[0,1) = \cap_n (-\frac{1}{n}, 1)$, so a $G_\delta$ as well. It's also an $F_\sigma$, as $[0,1) = \cup_n [0,1-\frac{1}{n}]$, but neither open or closed.
Henno Brandsma
  • 250,824
Hint: The $G_\delta$ sets in $\mathbb R$ are precisely the sets of continuity points of a function. So, for each of the sets you're given, try to find a function that is continuous exactly in the set. This may be easier than using the definition of $G_\delta$ set.
lhf
  • 221,500
