21
An epimorphism is defined as follows:
$f \in \operatorname{Hom}_C(A,B)$ is an epimorphism if $\forall Z, \forall h', h'' \in \operatorname{Hom}_C(B, Z)$ then $h' f = h'' f \; \Rightarrow \; h' = h''$.
I can't think of examples where epimorphism would not have a right inverse.
Also, if I understand correctly, epimorphism is not surjective in the categories where we can't talk about surjection (where objects does not have internal structure?).
Thanks in advance.
user26857
  • 53,190
Daniil
  • 1,207
    Take the category of a partially ordered set. Every arrow is an epimorphism, but no non-identity arrow has a right inverse. – Arturo Magidin Nov 11 '11 at 14:51
    Try playing with (Hausdorff) topological spaces and continuous maps, for example. The map $x \mapsto e^{ix}$ from $\mathbb{R} \to S^1$ is surely epi but has no continuous right inverse. A morphism is epi if and only if it has dense range. – t.b. Nov 11 '11 at 14:52
    In the category of rings, epimorphisms do not, in general, have right inverses. For example, $f:\mathbb Z \rightarrow \mathbb Z/
    $ has no right inverse.
    – Thomas Andrews Nov 11 '11 at 14:53
    In some categories, "morphisms" are not represented as functions of sets, so we can't say a morphism is "surjective," in general, only that it is epimorphic. – Thomas Andrews Nov 11 '11 at 14:55
    In the category of rings an epimorphism does not even have to be surjective. Take the natural embedding of $\mathbb{Z}$ in $\mathbb{Q}$. Since $\mathbb{Q}=Quot(\mathbb{Z})$ every morphism with domain $\mathbb{Q}$ is already defined by its values on $\mathbb{Z}$. Therefore the embedding is a non-surjective epimorphism. – Sebastian Schoennenbeck Nov 11 '11 at 15:09
5 Answers5
53
Take the category of a partially ordered set; every arrow is an epimorphism, but no non-identity arrow has a right inverse.
For a concrete category (objects are sets and morphisms are functions between the underlying sets), take the category of Hausdorff topological spaces; an epimorphism is a continuous map with dense image. Consider $\mathbb{Q}\hookrightarrow \mathbb{R}$. This is an epimorphism, but there is no retract (no right inverse). Or the map $[0,2\pi)\to S^1$ given by $t\mapsto (\cos t,\sin t)$. If it had a right inverse in the category, the inverse would be a bijection, hence we would have homeomorphisms, but $[0,2\pi)$ and $S^1$ are not homeomorphic.
For yet another, take $\mathbb{Z}\hookrightarrow\mathbb{Q}$ in the category of rings with unity. This is an epimorphism, but does not have a right inverse.
Even in concrete categories where all epis are surjective, you need not have right inverses. In the category of groups, an epimorphism $G\to K$ has a right inverse if and only if $G$ is a semidirect product $G\cong N\rtimes K$. So take $\mathbb{Z}/4\mathbb{Z}\to \mathbb{Z}/2\mathbb{Z}$ for a surjective morphism (hence an epi) with no right inverse in the category.
Arturo Magidin
  • 417,286
    +1 for elaborating on differtn types of counterexamples. – Hagen von Eitzen Sep 12 '12 at 06:09
  • So the part "with unity" can be dropped in the third paragraph by your other answer. – user557 Jul 26 '19 at 02:46
  • @user634426: Those are two different assertions: it is an epimorphism in the category if rings with unity; it is also an epimorphism in the category of rings that do not necessary have unities. Both are correct. – Arturo Magidin Jul 26 '19 at 03:17
  • @ArturoMagidin I thought that the former implies the latter, but apparently it doesn't. – user557 Jul 26 '19 at 03:19
    @user634426: Well, both are true, so the implication holds; but you cannot deduce the latter from the former “categorically” (if $\mathbf{C}$ is a subcategory of $\mathbf{D}$ it does not follow that if $f$ is an epi in $\mathbf{C}$ then it is also an epi in $\mathbf{D}$, even if $\mathbf{C}$ is a full subcategory. The implication does hold in the opposite direction; here we only need an example, not the most general possible example. – Arturo Magidin Jul 26 '19 at 03:23
  • This is a nice list of counterexamples :) – Nico Apr 01 '20 at 10:41
13
Let $ \textbf{Ring}_{\text{Assoc}} $ be the category of associative (not necessarily unital) rings. We take the morphisms in this category to be maps between associative rings that preserve ring addition and ring multiplication. Note that it is irrelevant to speak of unit-preserving maps in this category as rings may not be unital.
Now, let $ i: \mathbb{Z} \rightarrow \mathbb{Q} $ be the inclusion map. We claim that it is an epimorphism. Let $ f,g: \mathbb{Q} \rightarrow R $ be two morphisms from $ \mathbb{Q} $ to another ring $ R $ such that $ f \circ i = g \circ i $. Hence, $ f(n) = g(n) $ for all $ n \in \mathbb{Z} $. Let $ \dfrac{a}{b} \in \mathbb{Q} $. Then \begin{align} f \left( \frac{a}{b} \right) &= f \left( \frac{1}{b} \cdot a \right) \\ &= f \left( \frac{1}{b} \right) *_{R} f(a) \\ &= f \left( \frac{1}{b} \right) *_{R} g(a) \\ &= f \left( \frac{1}{b} \right) *_{R} g \left( b \cdot \frac{a}{b} \right) \\ &= f \left( \frac{1}{b} \right) *_{R} \left[ g(b) *_{R} g \left( \frac{a}{b} \right) \right] \\ &= f \left( \frac{1}{b} \right) *_{R} \left[ f(b) *_{R} g \left( \frac{a}{b} \right) \right] \\ &= \left[ f \left( \frac{1}{b} \right) *_{R} f(b) \right] *_{R} g \left( \frac{a}{b} \right) \\ &= f \left( \frac{1}{b} \cdot b \right) *_{R} g \left( \frac{a}{b} \right) \\ &= f(1) *_{R} g \left( \frac{a}{b} \right) \\ &= g(1) *_{R} g \left( \frac{a}{b} \right) \\ &= g \left( 1 \cdot \frac{a}{b} \right) \\ &= g \left( \frac{a}{b} \right). \end{align} Therefore, $ f = g $, which implies that $ i: \mathbb{Z} \rightarrow \mathbb{Q} $ is indeed an epimorphism. This result strengthens the one mentioned by Arturo above.
  • This is in a way an application of the universal property of the field of fractions. Any canonical inclusion of an integral domain that isn't a field into its field of fractions should give analogous examples. – Max Demirdilek Jan 29 '22 at 14:08
9
Let $C$ be the category containing one object $\mathbb Z$, and morphisms being functions $f_n(z)=nz$ for $n\in\mathbb Z^+$. Then $f_n\circ f_m = f_{nm}$, and we can see that:
$$f_n\circ f_k = f_n\circ f_l \implies f_k=f_l$$
And similarly:
$$f_k\circ f_n = f_l\circ f_n \implies f_k=f_l$$
So every $f_n$ is an epimorphism and a monomorphism, but only $f_1$ has a left or right inverse. Note that $f_n$ is never surjective, if $n>1$, even though it is an epimorphism.
If you defined $C'$ in the same way, but with the object being $\mathbb Q$ and, for $n\in\mathbb Z^+$, $f_n(q)=nq$ is defined as a function on $\mathbb Q$, then this new category is (in some sense) isomorphic to $C$, and all functions are surjective and injective.
Thomas Andrews
  • 186,215
I should have known this for years, but I actually learned it only today:
Let $K$ be a field of characteristic $0$. In the category of finite-dimensional (!) Lie algebras, the inclusion map of the standard Borel subalgebra
$$\{\pmatrix{a&b\\0&-a}: a,b \in K \}$$
into $$\mathfrak{sl}_2(K) = \{\pmatrix{a&b\\c&-a}: a,b,c \in K \}$$
is an epimorphism (and obviously not surjective). Actually, so is the inclusion of any Borel (and hence any parabolic) subalgebra of a split semisimple Lie algebra.
Note that in the category of all Lie algebras over a given field, indeed epimorphisms are surjective, but one really needs infinite-dimensional Lie algebras for this.
In the category of monoids, the inclusion map $\iota:\mathbb N\to\mathbb Z$ is an epimorphism, but it is obviously not surjective. (Here, I consider $0$ to be a natural number.)
Proof. Suppose $M$ is a monoid (written using multiplicative notation), and $\alpha,\beta:\mathbb Z\to M$ are monoid homomorphisms such that $\alpha\circ \iota=\beta\circ\iota$. By hypothesis, the maps $\alpha$ and $\beta$ coincide on $\mathbb N$; we want to show that they coincide on the negative integers too.
Let $n>0$. Note that $\alpha(n)$ is invertible; indeed, \begin{align} \alpha(n)\alpha(-n)=\alpha(-n)\alpha(n)=\alpha(0)=1 \, , \end{align} whence $\alpha(-n)=\alpha(n)^{-1}$. Similarly, $\beta(-n)=\beta(n)^{-1}$. Thus, $$ \alpha(-n)=\alpha(n)^{-1}=\beta(n)^{-1}=\beta(-n) \, \blacksquare $$
Joe
  • 22,603
