I'm working through SICP MIT course, and I'm a little lost on how to prove the following statement. I think I'm able to demonstrate it, but have no idea how to prove this statement.
Proof statement
I may misunderstand the statement itself, although I was able to show for e.g, that Fib(3) was closer to $\Large{\frac{a^3}{\sqrt{5}}}$ than Fib(2), or Fib (4).
With regards to the hint, I'm not sure where this comes into play, although I can already see that it belongs to the Fibonacci formula.
This is the first part of the rest, which is an inductive proof of the Fibonacci sequence (which I know how has been a recurring question).
Any help would be a appreciated.
stantona
  • 101
  • http://math.stackexchange.com/questions/65011/prove-this-formula-for-the-fibonacci-sequence and https://proofwiki.org/wiki/Euler-Binet_Formula – lab bhattacharjee May 26 '14 at 16:19
    "Demonstrating" and "proving" are synonyms. Follow lab bhattacharjee's links and you should be fine. – Hubble May 26 '14 at 16:23
    Are you allowed to use that $F_n$ is an integer equal to $\frac{\phi^n}{\sqrt5}-\frac{\psi^n}{\sqrt5}$? If so, I imagine you could simply prove that the absolute value of the second term is less than $\frac12$. – Mike May 26 '14 at 16:32
$\phi^n = F_{n-1} + F_n \phi$, and $ \psi^n = F_{n-1} + F_n \psi$. Therefore, $$F_n = \frac{1}{\sqrt{5}} \phi^n - \frac{1}{\sqrt{5}} \psi^n$$.
$-1< \psi <0$ and $2< \sqrt{5} <3$, therefore $0 < | \frac{1}{\sqrt{5}} \psi^n | <\frac{1}{2}$
Let's assume, there is integer $A$, which closer to $\frac{1}{\sqrt{5}} \phi^n$ than $F_n$, and $A = \frac{1}{\sqrt{5}} \phi^n - \alpha$, where $0 < | \alpha | < | \frac{1}{\sqrt{5}} \psi^n |$.
Therefore, $A - F_n = \frac{1}{\sqrt{5}} \psi^n - \alpha$ should also be integer.
But, because of $0< | \alpha | < | \frac{1}{\sqrt{5}} \psi^n | < \frac{1}{2}$, the difference $\frac{1}{\sqrt{5}} \psi^n - \alpha$ cannot be integer. (Further explanation may be needed.....)
So, $ \; \LARGE{F_n} \;$ is the closest integer to $ \; \; \LARGE{\frac{1}{\sqrt{5}} \phi^n} \; $.
Seeing the form of the solution should lead you to explore how Fibonacci numbers can be represented by an exponential law.
Try $F_n=t^n$ as a possible solution and inject that in the definition by recurrence:
$$F_n=t^n=F_{n-1}+F_{n-2}=t^{n-1}+t^{n-2}.$$
Simplifying by $t^{n-2}$, you get:
$$t^2=t+1,$$ giving two different solutions, namely $\phi^n$ and $\psi^n$, corresponding to the roots $t=\phi$ and $t=\psi$ of this second degree equation.
But you are not done yet, as none of these exponentials satisfy the initial conditions $F_0=F_1=1$.
You now have to observe that the recurrence equation is linear, meaning that any linear combination of solutions is also a solution: $$\phi^n=\phi^{n-1}+\phi^{n-2}\land\psi^n=\psi^{n-1}+\psi^{n-2}\implies a\phi^n+b\psi^n=a\phi^{n-1}+b\psi^{n-1}+a\phi^{n-2}+b\psi^{n-2}$$
It remains to determine $a$ and $b$, from: $$\begin{align}F_0=a\phi^0+b\psi^0&=1\\ F_1=a\phi^1+b\psi^1&=1.\end{align}$$
Lastly, you will check why the $\psi^n$ term can be replaced by the rounding of the $\phi^n$ term.
