In http://isfaserveur.univ-lyon1.fr/~stephane.loisel/prerequis_esp_cond.pdf
Recall the definition of conditional probability associated with Bayes’ Rule
$$P(A|B) ≡ \frac{P(A \cap B)}{P(B)}$$
For a discrete random variable $X$ we have $$P(A) = \sum_x P(A, X = x) = \sum_x P(A|X = x)P(X = x) $$
and the resulting formula for conditional expectation $$ E(Y |X = x) = \int_\Omega Y (\omega)P(d\omega|X = x) = \frac{\int_{X=x} Y (\omega)P(d\omega)}{P(X = x)} = \frac{E(Y \, 1_{(X=x)})}{P(X = x)} $$
I was wondering why $ \int_\Omega Y (\omega)P(d\omega|X = x) = \frac{\int_{X=x} Y (\omega)P(d\omega)}{P(X = x)}$ in the last equation?
Thanks and regards!
Tim
  • 49,162
I will give you an argument that works under two additional hypothesis:
  1. $Y\in L^1$;
  2. $\mathbb{P}(X=x)\neq 0$.
We first establish this result for characteristic functions. If $Y=1_{A}$ for some measurable set $A$ we have that $$ \begin{eqnarray} \int_{\Omega} 1_A(\omega)\ \mathbb{P}(d\omega|X=x) &=&\mathbb{P}(A|X=x) \\ &=& \frac{\mathbb{P}(A\cap \{X=x\})}{\mathbb{P}(X=x)}=\frac{1}{\mathbb{P}(X=x)}\int_{\{X=x\}} 1_A(\omega) \ d\mathbb{P}(\omega). \end{eqnarray} $$
By linearity of the integral you can prove this formula for any simple function. Let us suppose that $Y\in L^1$ and $Y(\omega)\geq 0$ for all $\omega\in\Omega$. In this case note that there is a monotone sequence of simple functions that converges to $Y$, by using the monotone convergence theorem we can see that the formula also holds for $Y$. For general $Y\in L^1$, just split it in its positive and negative part and argument similarly we did before.
Srivatsan
  • 26,761
Leandro
  • 2,440
  • Thanks! I wonder why $Y \in L^1$ is required? The existence of a monotone sequence of simple functions does not require it, and the monotone convergence theorem does not either. – Tim Oct 31 '11 at 03:35
  • @Tim I think the problem is when $Y$ change sign and not integrable. I guess you can't argue taking limit for the positive part and then to negative part and sum both. – Leandro Oct 31 '11 at 03:53
    So by "taking limit for the positive part and then to negative part and sum both.", are you talking about the definition of integral of $Y$ over $\Omega$? That does not require $Y$ to be integrable, but only that at least one of its positive and negative parts is. So is $Y \in L^1$ still required in answering my question? – Tim Oct 31 '11 at 04:45
  • @Tim nice observation. The hypothesis $Y\in L^1$ can be replaced by the condition that either positive or negative part of $Y$ is integrable. – Leandro Oct 31 '11 at 04:54
