This problem addresses the same question that has been asked in $A^m\hookrightarrow A^n$ implies $m\leq n$ for a ring $A\neq 0$, which is exercise 2.11 of Atiyah and Macdonald's Introduction to Commutative Algebra. The reason I am posting this again is because although the other threads provided a complete answer, there are additional questions that arise from the problem that are of concern to me. Specifically, I would like to know whether the following is true:
Problem. Let $f:A^m\rightarrow A^n$ be a monomorphism of $A$-modules with $A$ a non-zero commutative ring. Let $I\subset A$ be a maximal ideal in $A$. Is the following map injective $$f\otimes 1:A^m\otimes_A(A/I)\rightarrow A^n\otimes_A(A/I),\enspace (f\otimes 1)(a\otimes \bar{b})=f(a)\otimes \bar{b}\ ? $$
Discussion\Solution: Manos has pointed out the error in my proof, see the EDIT section below for additional discussion I know that in general tensor products are right exact, and so if we replace monomorphism by epimorphism then then statement always holds. Unfortunately we cannot use exactness here since the tensor product is not in general left exact (if $A/I$ is a flat module, we can use exactness). The reason I am considering the above homomorphism is because it is a $A/I$-linear transformation of $A/I$ -vector spaces, and thus if the result holds then $m\leq n$ since no injective linear transformation sends a vector space of higher dimension to one of lower dimension.
Set $k=A/I$. For $r=m,n$ we have that $A^r\otimes_A k$ is a $k$-vector space with basis $\{e_i\otimes 1: 1\leq i \leq r\}$. I will denote elements in $k$ by $[a]$ with $a\in A$.
Suppose that $\sum_{i=1}^m[\lambda_i](e_i\otimes 1)\in Ker(f\otimes 1)$. Then: \begin{align} (f\otimes 1)\left(\sum_{i=1}^m[\lambda_i](e_i\otimes 1) \right)&=(f\otimes 1)\left(\sum_{i=1}^m(e_i\otimes [\lambda_i]) \right)\\ &=\sum_{i=1}^m(f(e_i)\otimes [\lambda_i])\enspace (*)\\ \end{align}
For each $i$, $f(e_i)\otimes [\lambda_i]=f(e_i)\otimes \lambda_i\cdot [1]=\lambda_i f(e_i)\otimes 1=f(\lambda_ie_i)\otimes 1$ since $f$ is a homomorphism of $A$-modules (and by how the $A$ module structure on $A/I$ is defined). Then we have: $$(*)=\sum_{i=1}^m(f(\lambda_ie_i)\otimes 1)=\left(\sum_{i=1}^m f(\lambda_ie_i) \right)\otimes 1 =f\left(\sum_{i=1}^m \lambda_ie_i \right)\otimes 1 $$ Again, this holds since $f$ is a homomorphism of $A$-modules. Since our initial assumption was that $\sum_{i=1}^m[\lambda_i](e_i\otimes 1)\in Ker(f\otimes 1)$, $$f\left(\sum_{i=1}^m \lambda_ie_i \right)\otimes 1 =0 $$
From this it would be nice to conclude that each $\lambda_i\in I$ which then implies that $\sum_{i=1}^m[\lambda_i](e_i\otimes 1)=0$. This is the part I am not sure about. Clearly by the injectivity of $f$, $$f\left(\sum_{i=1}^m \lambda_ie_i \right)=0\iff \lambda_i=0\enspace \forall i $$ So we can omit this case. Thus $f\left(\sum_{i=1}^m \lambda_ie_i \right)=a\neq 0 \in A^n$. The only other time I can see the tensor $a\otimes 1$ being zero is if $a\in I\cdot A^n$, which should then imply that $ \sum_{i=1}^m \lambda_ie_i \in I\cdot A^m\implies \lambda_i\in I$ for all $i$. But I am not sure about this last statement or that this is the only time an element of this $k$-vector space is $0$.
If someone could read through this and help me out that would be great!
EDIT. I am really just trying to come up with a proof that doesn't use Cayley-Hamilton for modules or determinants/linear algebra for modules (we have not discussed either in this class). We have covered basically the first two Chapters of Atiyah and Macdonald, but we skipped the Cayley-Hamilton theorem for modules and have not done any computations involving the matrix theory of modules. As Martin Brandenburg has kindly mentioned, it is possible that this question was given to us with the assumption that Cayley-Hamilton would be covered, which seems to seem very possible. The proofs in http://www.mathoverflow.net/questions/136, http://www.mathoverflow.net/questions/30860 or http://www.math.stackexchange.com/questions/106786 are very well done and I in particular like the Cayley-Hamilton one, but I was hoping to come up with a proof that only used concepts that have been covered in class, such as the basic properties of tensor products, exact sequences, modules (excluding Cayley-Hamilton and matrix theory) and rings.
CWsl2
  • 1,432
    Tensor $2 : \mathbb{Z} \to \mathbb{Z}$ with $\mathbb{F}_2$, it gets zero. General advice: Think about examples and structural arguments before diving into long element calculations ... – Martin Brandenburg Feb 06 '14 at 00:05
  • can you elaborate on your comment? I am not sure I understand what you are saying. Edit: Nevermind I see it. I don't see where the proof goes wrong though, that is what I am interested in finding out. – CWsl2 Feb 06 '14 at 00:07
  • Okay thanks I see now that it just goes wrong in that last step. I am still interested in a proof that does not use Cayley-Hamilton or matrix theory though – CWsl2 Feb 06 '14 at 00:19
  • You can find dozens of proofs in the linked question, as well as in the linked MO thread there. And yes, also many which do not use matrices or Cayley Hamilton. For example, Georges Elencwajg has presented a nice proof reducing to the case of artinian rings and then using the additivity of the length of a module. – Martin Brandenburg Feb 06 '14 at 00:21
  • There is only one proof listed among all those proofs that I can see does not use Cayley hamilton or matrix theory that is the proof in Lam- which depends on the notion of stably finite and noetherian rings among other things (this is the closest thing to a proof I have found that is accesible at our point in the class). So I don't really see what these "many" arguments are. I was hoping to construct an alternative proof- I suspected since it was a homework question and that we have not covered these additional things in class that would be possible. – CWsl2 Feb 06 '14 at 00:28
  • Then please ask a new question including details what your professor has covered (and what not) so far in the lecture. I will certainly try to help then. – Martin Brandenburg Feb 06 '14 at 00:30
  • It would also be good if you include specific reasons why none of the proofs in http://mathoverflow.net/questions/136 , http://mathoverflow.net/questions/30860 or http://math.stackexchange.com/questions/106786/ satisfy you (also in order to prevent potential close votes!). – Martin Brandenburg Feb 06 '14 at 00:36
    It is also possible that your professor / assistant didn't realize before if the exercise is solvable with the methods you have covered so far. Some assistants (not sure if this is the right word in english; I mean the one who helps to create the exercises and works together with the professor) just copy exercises from books. – Martin Brandenburg Feb 06 '14 at 00:38
  • I think you could be correct Martin that this question was perhaps given in the false pretence that we had covered Cayley-Hamilton. I'll send the professor an email, in the meantime I have taken your advice and added some edits to my OP. – CWsl2 Feb 06 '14 at 00:45
    Have you seen Keith Conrad's proof using exterior powers? It is Cor. 5.11 in http://www.math.uconn.edu/~kconrad/blurbs/linmultialg/extmod.pdf. The main ingredient is Thm. 5.10, which is a consequence of Thm. 4.2., which is just the usual basis of the exterior power of a free module. Notice that this is a coordinate-free version of the proof using minors and matrices. In my opinion this is the most elegant proof. – Martin Brandenburg Feb 06 '14 at 00:49
  • Yes, I actually really like the argument and Have dealt a bit with Exterior algebras in a Lie theory graduate course I did last year- but only in the case of dealing with vector spaces over fields. Thanks though, it is a nice argument. – CWsl2 Feb 06 '14 at 00:52
Let me reproduce the proof given by Keith Conrad in his notes on exterior powers. I will present it in a self-contained way. We really only need the definition of the exterior power $$\Lambda^n M := M^{\otimes n} / \langle m_1 \otimes \dotsc \otimes m_n : m_i = m_j \text{ for some } i \neq j \rangle.$$
Theorem: Let $M,N$ be free $A$-modules, and $\phi : M \to N$ be an injective homomorphism. Then for every $n \geq 0$ also $\Lambda^n \phi : \Lambda^n M \to \Lambda^n N$ is an injective homomorphism.
This implies that $A^n$ does not embed into $A^m$ for $n>m$, since otherwise$^\textbf{1}$ $A \cong \Lambda^n A^n $ embeds into $\Lambda^n A^m = 0$.
Proof of the Theorem. Since free modules are flat, we see by induction that $\phi^{\otimes n} : M^{\otimes n} \to N^{\otimes n}$ is injective. The map $M^n \to M^{\otimes n}$ which maps $(m_1,\dotsc,m_n)$ to $\sum_{\sigma \in \mathfrak{S}_n} \mathrm{sgn}(\sigma) \cdot m_{\sigma(1)} \otimes \dotsc \otimes m_{\sigma(n)}$ is multilinear alternating (check this!), hence lifts to a linear map $\alpha_M : \Lambda^n M \to M^{\otimes n}$. The diagram $$\begin{array}{c} \Lambda^n M & \xrightarrow{\alpha_M} & M^{\otimes n} \\ \downarrow && \downarrow \\ \Lambda^n N & \xrightarrow{\alpha_N} & N^{\otimes n} \end{array}$$ is commutative. Therefore, it suffices to prove that $\alpha_M$ is injective (because then also $\phi^{\otimes n} \circ \alpha_M = \alpha_N \circ \Lambda^n \phi$ and therefore $\Lambda^n \phi$ is injective).
For this choose an ordered basis $B$ of $M$. Then clearly $\{b_1 \wedge \dotsc \wedge b_n : b_1 < \dotsc < b_n \text{ in } B\}$ is a generating set$^\textbf{1}$ of $\Lambda^n M$. Let $\omega = \sum_{b_1 < \dotsc < b_n} \lambda(b_1,\dotsc,b_n) \cdot (b_1 \wedge \dotsc \wedge b_n)$ be an element in the kernel of $\alpha_M$. Then in $M^{\otimes n}$ we have $$0 = \sum_{\sigma \in \mathfrak{S}_n} \sum_{b_1 < \dotsc < b_n} \lambda(b_1,\dotsc,b_n) \cdot \mathrm{sgn}(\sigma) \cdot b_{\sigma(1)} \otimes \dotsc \otimes b_{\sigma(n)}.$$ Since $\{b_{\sigma(1)} \otimes \dotsc \otimes b_{\sigma(n)} : \sigma \in \mathfrak{S}_n, b_1 < \dotsc < b_n \}$ is a subset of the basis $\{b_1 \otimes \dotsc \otimes b_n : b_i \in B\}$ of $M^{\otimes n}$, we conclude that $\lambda(b_1,\dotsc,b_n) \cdot \mathrm{sgn}(\sigma)$ and hence $\lambda(b_1,\dotsc,b_n)$ vanishes for all $b_1<\dotsc<b_n$. Thus, $\omega=0$. $\square$
$^\textbf{1}$ This argument actually shows that $\{b_1 \wedge \dotsc \wedge b_n : b_1 < \dotsc < b_n \text{ in } B\}$ is a basis of $\Lambda^n M$. In particular $A \cong \Lambda^n A^n$ and $0 = \Lambda^n A^m$ for $n>m$.
If $f(\sum_{i=1}^m \lambda_i e_i) \otimes 1 =0$, then indeed we must have that $f(\sum_{i=1}^m \lambda_i e_i) \in I A^n$. The error in your proof is that this last relation does not imply that $\lambda_i \in I$.
Manos
  • 26,949
One can see the error also in another way. Since $A^n$ is projective, hence flat, we have $\def\Tor{\operatorname{Tor}}\Tor^A_1(A^n,X)=0$ for all modules $X$; similarly, $\Tor^A_1(X,A)=0$. If you tensor by $A/I$ the exact sequence $$ 0\to A^m\to A^n\to C\to 0 $$ where $C$ is the cokernel of your map, you get the exact sequence $$ 0=\Tor^A_1(A^n,A/I)\to\Tor^A_1(C,A/I)\to A^m\otimes A/I\to A^n\otimes A/I \to C\otimes A/I\to 0 $$ You can compute $\Tor^A_1(C,A/I)$ by tensoring by $C$ the exact sequence $0\to I\to A\to A/I\to 0$, which gives $$ 0=\Tor^A_1(C,A)\to\Tor^A_1(C,A/I)\to C\otimes I\to C\otimes A\to C\otimes A/I\to 0 $$ Now you see that $$ \Tor^A_1(C,A/I)=\ker(C\otimes I\to CI) $$ because the epimorphism $C\otimes A\to C\otimes A/I$ is the canonical projection $C\to C/CI$ under cover, so its kernel is isomorphic to $CI$. The morphism $C\otimes I\to CI$ is not necessarily injective.
egreg
  • 244,946
  • Oh, when I started to read the answer, I was hoping to find an alternative proof using Tor functors. :) – Martin Brandenburg Feb 06 '14 at 20:28
  • @MartinBrandenburg Only if one is able to find a suitable maximal ideal $I$ such that $\operatorname{Tor}^A_1(C,A/I)=0$. This might be possible. – egreg Feb 06 '14 at 20:35
