My goal is to put $n$ points on a sphere in $\mathbb{R}^3$ to divide it in $n$ parts, so that their disposition would be as "equivalent" as possible. I don't exactly know what "equivalent" mathematically means, perhaps that the min distance between two points is maximal.
Anyway in $2$ dimensions it is simple to divide a circle in $n$ parts. In $3$ dimensions I can figure out some good re-partitions for particular values of $n$ but I lack a more general approach.
Y-O
  • 61
    Related: http://math.stackexchange.com/questions/9846/which-tessellation-of-the-sphere-yields-a-constant-density-of-vertices/, http://math.stackexchange.com/questions/31619/well-separated-points-on-sphere, http://math.stackexchange.com/questions/51009/optimal-number-of-points-for-integration-over-the-surface-of-a-sphere –  Aug 17 '11 at 17:10
  • Given $n$ points on a circle $S^1$ these points divide $S^1$ in $n$ parts in an obvious way, and it is easy to describe a configuration where these points are "equivalent". On a $2$-sphere this is another matter. If your $n$ points are the vertices of a regular $n$-gon on the equator they are certainly "equivalent" insofar as there is a group of isometries of $S^2$ permuting these points transitively. But perhaps you have something else in mind. In any case, $n$ points on $S^2$ do not divide $S^2$ into $n$ parts without further ado. – Christian Blatter Aug 17 '11 at 19:56
  • The ones cited by Rahul Narain may be better, but you could also look at http://math.stackexchange.com/questions/11499/possible-to-imitate-a-sphere-with-1000-congruent-polygons/11512#11512 – Ross Millikan Apr 14 '12 at 02:58
A nontrivial problem, I think. You might find some links into the research literature on Ed Saff's homepage.
Hans Lundmark
  • 55,038
  • That link is broken but https://my.vanderbilt.edu/edsaff/spheres-manifolds/#equal-area-points and http://eqsp.sourceforge.net/ may help – Henry Jul 22 '18 at 02:20
You can try the physical method: treat each point as an electron constrained in a sphere, and randomly distribute these point particles in the sphere, then you can solve the equations of motion to reach a stable (minimum energy) state, where each particle maximally separated from its closest neighbours (electric repulsive forces). Here is how to apply this method on a sphere surface.
chaohuang
  • 6,579
