Motivation
It often happens to me that I calculate an integral and find that by doing the integration by parts the integral diverges.
Basic example
$$\int_0^{\infty}\frac{\sin(t)}{t}\mathrm{d}t=\frac{\pi}{2}$$ but $$\int_0^{\infty}\frac{\cos(t)}{t^2}\mathrm{d}t\to\infty\qquad\text{and}\qquad\int_0\cos(t)\ln(t)\mathrm{d}t\to\infty$$
In both cases, by moving an entire derivative to one or the other term, the integral diverges, so I wondered if it was possible to "lighten" the load moved.
My link
Thinking about diffusion problems (where there are second derivatives in the Laplacian), the solutions enter their "natural space" $H^1$ when writing the variational formulation, hence when you dump a derivative on the test function, and we had seen a case where it made sense to dump half a derivative on the test function to make the order of the derivatives on the test solution and the solution equal (in practice only to set it in the correct Sobolev space).
My question
Is it possible to generalize the integration by parts formula using fractional derivatives?
My idea
I had to try to find it myself by taking the fractional derivative of a product of functions and then integrating to obtain one of the two expressions, but Leibniz's formula does not apply to fractional derivatives.
$$\frac{\mathrm{d}^n}{\mathrm{d}x^n}f(x)g(x)=\sum_{k=0}^{n}\binom{n}{k}f^{(k)}(x)g^{(n-k)}(x)$$ In the case in question I thought (I don't know if it's correct) that a formula by analogy could be valid as for the series of a power of a binomial
$$\frac{\mathrm{d}^\alpha}{\mathrm{d}x^\alpha}f(x)g(x)\mathrm{d}x\overset{?}{=}\sum_{k=0}^{\infty}\binom{\alpha}{k}f^{(k)}(x)g^{(\alpha-k)}(x)$$
In general I have
$$\int f(x)g^{(n)}(x)\mathrm{d}x=\sum_{k=0}^{n-1}(-1)^k f^{(k)}g^{(n-k)}(x)+(-1)^n\int f^{(n)}(x)g(x)\mathrm{d}x$$ So maybe there is a similar formula that could have a form like this
$$\int f(x)g^{(\alpha)}(x)\overset{?}{=}\sum_{k=0}^{\infty}(-1)^k f^{(k)}g^{(\alpha-k)}(x)+c_{\alpha}\int f^{(\alpha)}(x)g(x)\mathrm{d}x$$
Link with Laplace transform
A similar formula also exists for Laplace transforms.
$$\int _{0}^{\infty }f(x)g(x)\mathrm{d}x=\int _{0}^{\infty }({\mathcal {L}}f)(s)\cdot ({\mathcal {L}}^{-1}g)(s)\mathrm{d}s$$
"Similar" in the sense that it follows the philosophy of applying one operator to one function and the inverse operator to the other function (if you think of the derivative as an operator).
The discussion could also be generalized by asking to find all the $\mathcal{A}$ operators that satisfy the property
$$\int f(x)\cdot g(x)\mathrm{d}x=C_a\int \mathcal{A}[f](t)\cdot \mathcal{A}^{-1}[g](t)\mathrm{d}t$$ but for now I'll limit myself to fractional derivatives
Disclaimer
I used Google translate to write the post and I have the doubt that It may have mistranslated the term "dump" (for me it means that I move the derivative operator from one part to another).
