A problem on my midterms was multiple choice with 4 choices to choose from. The problem asked for what is equivalent to $$\sqrt[3]{\left(\frac{2}{3}\right)^{2}}$$ and there were two possible answers that were $$\left(-\frac{2}{3}\right)^{2/3}\quad \text{and}\quad \left(\frac{3}{2}\right)^{-2/3}$$ I claimed that these are equal.
So after the test I pulled up Desmos, plugged them in, and they all gave me 0.763142828369.
So then I asked wolfram alpha and I put in the -2/3^2/3 thing and got me an imaginary result. But I wasn't convinced because the cube root of any number is real and (-a)^2 = a^2. so i guess wolfram didn't do each step, and considered 2/3 as its own thing idk. but I do know that that's how sir taught us how to do fractional exponents, which is step by step and he would probably square -2/3 first and then do the rest.
But when I asked any teacher about the problem, they all said no with no explanation they didn't have any second thought. They were confident, so I decided I was confident with my answer.
So my real problem is either getting a more mature mathematician ('cause I'm only 16, and who would listen to what a 16 year old says) to defend me or I should just wait until schools open and I can discuss it with a teacher.
Evan
  • 135
  • Did you use parentheses? – Sean Roberson Jan 24 '25 at 18:48
    See also: https://math.stackexchange.com/questions/608023/what-is-1-frac23 – Matt Jan 24 '25 at 18:48
    This is the age old question of how to handle negative bases which depends on what the definition of $a^b$ in the first place anyway. When dealing with roots many, if not most, if not all, would claim if $a^{\frac bc} = (\sqrt[c] a)^b$ is the definition then allowing $a$ to be negative leads to inconsistant and ambiguous results and is simply not allowed. – fleablood Jan 24 '25 at 21:19
    I'm sorry you have such a by rote teacher. There are two issues. 1) $(-a)^{\frac 13}$ should equal $(-a)^{\frac 26}$ but $(-a)^2$ simply erases the negative sign. If you say that there is a neg and pos answer, then we still have an inconsistency that $(-a)^{\frac 26}$ has $6$ potential values while $(-a)^{\frac 13}$ has only $3$. The other issue is what is $(-a)^x$ if $x$ is irrational. We use the exponent and log functions to define $a^x$ and for consistance it requires that $a>0$.... tl;dr.... If you have $a^b$ and $b$ is not an integer, by convention $a$ must be positive. – fleablood Jan 24 '25 at 21:30
  • FWIW, Python gives $0.7631428283688879$ for ((2/3)**2)**(1/3) and (3/2)**(-2/3), but the complex number $(-0.3815714141844438+0.6609010760833648j)$ for (-2/3)**(2/3). – Dan Jan 24 '25 at 23:14
Recall that the cube root of $x$, denoted $\sqrt[3]{x}$ or $x^{1/3}$, is a number $z$ that satisfies the equation $z^3 = x$.
Note that I wrote “a number” instead of “the number”. Because, according to the Fundamental Theorem of Algebra, a polynomial of degree 3 can have as many as 3 distinct roots.
By convention, $\sqrt[3]{x}$ denotes the “principal” cube root of $x$. If you need the other two, they're $\omega\sqrt[3]{x}$ and $\overline{\omega}\sqrt[3]{x}$, where $\omega$ and $\overline{\omega}$ denote $-\frac{1}{2} \pm i\frac{\sqrt{3}}{2}$, the two non-real cube roots of 1.
This raises the question: Which of the three cube root is “principal”?
When $x$ is a nonnegative real number, this is straightforward: Pick the one that's real.
Otherwise, let $r = |x|$ and $\theta = \arg(x)$, so that $x = re^{i\theta} = r(\cos\theta + i\sin\theta)$. Then, by DeMoivre's Formula,
$$\boxed{\sqrt[3]{x} = \sqrt[3]{r}(\cos\frac{\theta}{3} + i\sin\frac{\theta}{3})}$$
So, for example, because $x=i$ gives $r=1$ and $\theta=\frac{\pi}{2}$,
$$\sqrt[3]{i} = \cos\frac{\pi}{6} + i\sin\frac{\pi}{6} = \frac{\sqrt{3}}{2} + i\frac{1}{2}$$
And for $x=-1$, $r = 1$ and $\theta = \pi$, so:
$$\sqrt[3]{-1} = \cos\frac{\pi}{3} + i\sin\frac{\pi}{3} = \frac{1}{2} + i\frac{\sqrt{3}}{2}$$
But wait! That means that the cube root of a real number can be a non-real number. What if you don't want complex numbers in your calculations?
Well, one way is to special-case the definition of the principal cube root so that $\sqrt[3]{-x} = -\sqrt[3]{x}$. For example, this is what a TI-89 or TI-92 calculator does when the complex number mode is set to “real”.
Now, let's consider what the expression $x^{2/3}$ means if $x$ is a negative real number.
If you calculate it as $(x^2)^{1/3}$, then the squaring cancels out the negation and you just get $|x|^{2/3}$.
But, if you use DeMoivre's or Euler's definition of complex exponentiation, representing the radicand in terms of $r$ and $\theta$, you get $r^{2/3}(\cos\frac{2\theta}{3} + i\sin\frac{2\theta}{3})$
And this is why Python and WolframAlpha give a non-real answer when you calculate $(-\frac{2}{3})^{2/3}$.
>>> (-2/3)**(2/3)
Point is, while an expression of the form $a^b$ is unambiguous when $a > 0$, things can get complex (pun intended) when $a < 0$.
Dan
  • 18,262
    omg i forgot about that, i always forget that whenever we're dealing with nth roots then theres gonna be n possibe answers. i also noticed that if you take the absolute value of the other complex results you get the real solution. so i guess i'll get 1.33333... marks on the problem :). thanks man for the reminder. i think ill just wait till school opens again. – Evan Jan 26 '25 at 02:53
