I found on Wikipedia that, even if $V = L$, $L_{\omega + 1} = V_{\omega + 1}$ doesn't hold. This seems counterintuitive to me, as I thought that this was basically the definition of $V = L$. I thought that $L_{\alpha} = V_{\alpha}$ for all $\alpha$, so that the constructible universe is "stable" under iteration. This still seems to be true (it's mentioned on the same Wikipedia page), but I'm still surprised that it doesn't hold for all $\alpha$.
It's here, near the top of the section. These sets seem small enough (and the model restrictive enough) that it'd be possible to describe exactly an element of one that isn't an element of the other. I hope to get this type of answer.
zaq
  • 1,100
No, $V=L$ means that $\bigcup_\alpha L_\alpha= \bigcup_\alpha V_\alpha,$ which just implies that for every $x\in V_{\omega+1}$, there is a $\beta$ such that $x\in L_\beta,$ not necessarily that $x\in L_{\omega+1}.$ This $\beta$ will generally be larger than $\omega+1.$
One observation is that you can prove by induction that $|L_\alpha|=|\alpha|$ for every infinite $\alpha.$ So in particular, $|L_{\omega+1}|=\aleph_0.$ Whereas, $|V_{\omega+1}|=2^{|V_\omega|}= 2^{\aleph_0}.$ So we usually have $L_\alpha \subsetneq V_\alpha$ just on a cardinality basis alone, since $|L_\alpha| = |\alpha|$ and $|V_{\alpha}| = \beth_\alpha$ (for $\alpha\ge \omega^2$).
Intutitively, since we only allow $L_\alpha$-definable subsets in at each point and there are only $|L_\alpha|$ of these, the cardinality of $L_\alpha$ holds still at successors and thus grows quite slowly compared to $V_\alpha,$ which takes full power sets each time and thus increases cardinality.
But still, after many iterations we will get fixed points $\alpha = \beth_\alpha,$ and the sizes will catch up then. It turns out when $V=L$ this is sufficient to make the sets themselves coincide and we have $V_\alpha = L_\alpha$ if and only if $\alpha = \beth_\alpha$ (or equivalently $\alpha = \aleph_\alpha$ since GCH holds in this case) or $\alpha\leq \omega$.
Since you asked for an explicit example of a set in $V_{\omega+1}\setminus L_{\omega+1}$, one example would be the set of all Gödel codes of true sentences in $V_\omega$, as this is not definable in $V_\omega=L_\omega.$
Every set in $L_{\omega+1}$ is arithmetically definable. So, for example, the theory of true first-order arithmetic will be in $L$ but not in $L_{\omega+1}$; more precisely, it will be in $L_{\omega+2}$. More generally, whenever $\alpha$ is a countable ordinal we will have $L_\alpha$ countable in $L$, and so there will be a real in $L$ - but necessarily not $L_\alpha$ - which codes an explicit enumeration of the reals in $L_\alpha$ (or indeed all of $L_\alpha$). The connection between computability-theoretic complexity and explicit countings can be made precise via mastercodes - see e.g. Hodes' paper. Interestingly, if $\alpha$ is really big (but still $<\omega_1^L$) we may have to wait quite some time before seeing a "counting" of $L_\alpha$ appear in $L$ - this is an immediate consequence of downward Lowenheim/Skolem and condensation (consider the Mostowski collapse of an elementary submodel of $L_{\omega_1^L+1}$) but for more details see Marek/Srebrny.
I think the source of your confusion is the conflation between $\mathcal{P}_{def}$ and $\mathcal{P}^L$ (here $\mathcal{P}^L$ is the powerset according to $L$, and $\mathcal{P}_{def}$ is the definable powerset operation). In general (in fact, in almost every case) we have, for $x\in L$, that $\mathcal{P}_{def}(x)\subsetneq\mathcal{P}^L(x)$.
Let me say a bit more about the surprising weakness of $\mathcal{P}_{def}$. Since models of even very weak set theories are very complicated objects, I'll tweak things to be applicable to a broader class of structures at the cost of (seemingly) introducing a bit of a discrepancy. To keep things unambiguous, I'll call the new operator "$\mathcal{D}$" rather than "$\mathcal{P}_{def}$."
Suppose $\mathfrak{A}$ is any structure (in the usual sense of first-order logic, but allowing multiple sorts). Let $\mathcal{D}(\mathfrak{A})$ be the structure gotten from $\mathfrak{A}$ by adding an additional sort, where the objects in that additional sort are just the definable-with-parameters subsets of $\mathfrak{A}$; to the language, we add a symbol "$\in$" connecting the new sort and elements of the original $\mathfrak{A}$ in the obvious way.
(Really we should be adding all the definable relations, not just the definable sets, but that won't affect the point here.)
Now one natural guess - especially coming from experience with expansions-by-definitions - is that $\mathcal{D}^2(\mathfrak{A})\cap\mathcal{P}(\mathfrak{A})=\mathcal{D}(\mathfrak{A})\cap\mathcal{P}(\mathfrak{A})$. However, this fails badly in general! The reason is that, while each individual object added in the construction $\mathfrak{A}\leadsto\mathcal{D}(\mathfrak{A})$ adds no expressive power, by treating them as objects rather than relations we've gained the ability to quantify over them and so in forming $\mathcal{D}^2(\mathfrak{A})$ we can use formulas like "For every definable-in-$\mathfrak{A}$ set $X$ ..."
Here's one example of this. Let $\mathfrak{A}=(\mathbb{Z};+,1)$. It is known that the set of positive integers is not definable in $\mathfrak{A}$, and so is not an element of (the new sort of) $\mathcal{D}(\mathfrak{A})$. However, it is definable in $\mathcal{D}(\mathfrak{A})$, and so is a subset of $\mathfrak{A}$ added in $\mathcal{D}^2(\mathfrak{A})$ but not $\mathcal{D}(\mathfrak{A})$. The reason that the set of positive integers is definable in $\mathcal{D}(\mathfrak{A})$ is cute, so I've spoilered it:
Say that a block is a set $S$ of integers such that $1\in S$, $0\not\in S$, there is exactly one $y\in S$ such that $y+1\not\in S$, and for every $z\in S$ with $z\not=1$ we have $z-1\in S$. There are two possible "shapes" for a block to have: either it's an interval $[1,k]$ for some positive $k$, or it's a "cointerval" - that is, of the form $[1,\infty)\cup(-\infty, k]$ for some negative integer $k$. Given a block $S$, we can tell which type it has by asking whether the unique $u$ with $u+u\in\{k,k+1\}$ is in $S$ or not in $S$ (handling the case $k=1$ separately). Finally, putting this all together we have that $z$ is positive iff it is in some block of interval type. And every block is definable in $\mathfrak{A}$, so we can in fact make this query in $\mathcal{D}(\mathfrak{A})$!
(Similar tricks show that iterating definability can behave in quite surprising ways. See e.g. the various observations made here and here.)
Finally, let me end by addressing the apparent discrepancy between $\mathcal{D}$ and $\mathcal{P}_{def}$, namely that the extra-sort-generation of the former lets us identify the "levels" of the construction while the latter does not obviously do such a thing. In fact, there is no discrepancy at all but this isn't obvious: we can show that there is a formula $\lambda(x,y)$ such that for every pair of ordinals $\alpha<\beta$, we have $$\{x:L_\beta\models\lambda(x,\alpha)\}=L_\alpha.$$ (This is a good, if lengthy, exercise; as a hint, first prove the weaker result where $\beta$ is required to be a limit ordinal.) Since throughout this answer we've been using definability with parameters, this means that $\mathcal{P}_{def}$ is really well-modeled (at least for the stuff we care about here) by $\mathcal{D}$.
(As a final very-unrelated aside, let me just point out that we can abstract this approach to general logics and not just general structures; see e.g. 1, 2.)
Noah Schweber
  • 260,658
  • Comments have been moved to chat; please do not continue the discussion here. Before posting a comment below this one, please review the purposes of comments. Comments that do not request clarification or suggest improvements usually belong as an answer, on [meta], or in [chat]. Comments continuing discussion may be removed. – Xander Henderson Dec 25 '24 at 04:30
  • @Noah Schweber Are you sure this definition of a positive integer works? Now that I'm reading it again, it seems like for $z = 0$ we get $I = \mathbb{N}$ as the only counterexample, but that shouldn't be definable. (Edited to remove my attempt, it doesn't work either.) – zaq Dec 25 '24 at 05:13
    @zaq Argh, good point. Fixed I think! (The point is that we can find the "midpoint" of the two endpoints of a set of the appropriate form, and then ask whether that midpoint is in the set itself.) – Noah Schweber Dec 25 '24 at 05:25
  • This new one is even cuter! Although, I think that actually just replacing the "for all definable sets" with "there exists a definable set" in your original would've worked (maybe this is what you were going for). Still, that relies on your more complex proof that none of the segments $[k, +\infty)$ are definable, so maybe this is better. – zaq Dec 25 '24 at 05:34
