In page 8, Section 2: Topological Spaces of Bredon's Topology and Geometry, he presents the 5th question as follows:
Suppose that $S$ is a set and that we are given, for each $x \in S$, a collection $\mathfrak{N}(x)$ of subsets of $S$ satisfying:
- $N \in \mathfrak{N}(x) \implies x \in N$,
- $N,M \in \mathfrak{N}(x) \implies \exists P\in\mathfrak{N}(x)$ s.t. $P\subseteq(N \cap M)$, and
- $x \in S \implies \mathfrak{N}(x) \neq \varnothing$.
Then show that there is a unique topology on $S$ such that $\mathfrak{N}(x)$ is a neighborhood basis at $x$, for each $x \in S$. (Thus a topology can be defined by the specification of such a collection of neighborhoods at each point.)
Now, what I have attempted the first time was to take $\{\mathfrak{N}(x) | x \in S\}$ as a subbasis (acting upon the comment in the parentheses), show that its topology (let $\tau$) makes each $\mathfrak{N}(x)$ a neighborhood basis at $x$ and it is the unique topology that does this. But, in this attempt, I realized I needed to describe $\tau$ and while attempting I couldn't conclude that $\tau$ makes each $\mathfrak{N}(x)$ a neighborhood basis at $x$ for each $x$ as I couldn't show an open set $U$ containing $x$ with $U \subseteq N \in \mathfrak{N}(x)$.
Next I thought that since neighborhoods do not need to be open sets themselves, it is more natural to take \begin{equation}\tag{Eq. 1} \bigcup\limits_{x \in S} \left \{\mathfrak{N}(x) \right \} = \{\mathfrak{N}(x_1) \} \cup \{ \mathfrak{N}(x_2)\} \cup \dots \end{equation} as a subbasis, i.e. union of elements of $\mathfrak{N}(x)$ for each $x \in S$.
Here I think I proved that $\mathfrak{N}(x)$ is a neighborhood basis at $x$ for each $x \in S$, let $x \in S$ be given, then:
- All elements in $\mathfrak{N}(x)$ are open and they contain $x$, so they are neighborhoods of $x$ by default,
- Given any neighborhood of $x$, let $K$, I have to show that for some $N \in \mathfrak{N}(x)$, $N \subseteq K$. Since $K$ is a n'hood of $x$, there exists an open set $U$ s.t. $x \in U \subseteq K$. Since $U$ is open wrt to the topology we have generated, $U$ is arbitrary union of finite intersections of elements of Eq.1. And since we can get open sets containing $x$ specifically from intersecting $N$'s from the same $\mathfrak{N}(x)$ (not like intersecting $N \in \mathfrak{N}(x_1)$ and $M \in \mathfrak{N}(x_2)$ where $x_1 \neq x_2$ and $x$ is an element of both), for some $N \in \mathfrak{N}(x)$, $N \subseteq U$, thus $N \subseteq K$. Hence $K$ contains an element from the neighborhood basis.
I am sorry if the second point is not very precise. But is my reasoning sound and valid and how do I go on and prove existence of such a topology? Can I somehow prove that it is the finest/coarsest topology instantiates the condition, does that imply uniqueness?
Thank you in advance for any help.
Attempt at a Proof Upon @Thorgott 's Comment
To make $\mathfrak{N}(x)$ a n'hood basis at $x$, we must have the following, every set in $\mathfrak{N}(x)$ is a n'hood of $x$, and any n'hood of of $x$ contains a set from $\mathfrak{N}(x)$. Maybe, we can define an open set as accepting the sets in $\mathfrak{N}(x)$ as neighborhoods of $x$ and later check that this definition of open sets verifies the second condition of $\mathfrak{N}(x)$ being a n'hood basis. Then, let: \begin{equation} \text{A subset } U \subseteq S \text{ is open if } \mathfrak{N}(x) \subseteq U \quad \forall x \in U. \end{equation} Observe that since $U$ contains a n'hood for every one of its points, it is a n'hood for its points. Hence we satisfy the openness characterization by neighborhoods. This way, we get the topology, denote it by $\tau$. Now the difficult part. We must show that: (1) $\tau$ is a well-defined topology, and (2) $\tau$ makes $\mathfrak{N}(x)$ a n'hood basis at $x$ for each $x \in S$, and (3) $\tau$ is unique.
For (1), it is easy to see that countable intersection of open sets is again open. The space itself contains $\mathfrak{N}(x)$ for all $x \in S$, thus it is open, and $\varnothing$ is vacuously open because $\mathfrak{N}() \subseteq \varnothing$. For arbitrary unions of open sets, since we are collecting over $\mathfrak{N}(x)$'s we'll still have openness. Thus $\tau$ is a well-defined topology.
For (2), we should check the second condition for $\mathfrak{N}(x)$ to be a n'hood basis, as the first condition is already given by definition. I.e. given a n'hood $N$ of a point $x \in S$, can we find an element $K$ in $\mathfrak{N}(x)$ such that $K \subseteq N$? If $N$ is a n'hood, then it contains an open set, let $U$, such that $x$ is contained within. By def'n of our openness, $U$ contains $\mathfrak{N}(x)$, and since $\mathfrak{N}(x) \neq \varnothing$, we definitely have such a set $K$ such that $K \subseteq N$. Thus $\mathfrak{N}(x)$ is a n'hood basis at $x$ for each $x \in S$.
For (3), why is that $\tau$ is unique? Because every open set is uniquely determined by its points, as its points uniquely determine $\mathfrak{N}(x)$. I believe this unique determination is mainly due to the first and second properties of definition of $\mathfrak{N}(x)$, as given $x \in S$, we can find non-empty sets in $\mathfrak{N}(x)$ such that they are subsets of intersections of sets in $\mathfrak{N}(x)$. And this property holds only for $k$ if $\mathfrak{N}(x = k)$. Thus uniqueness.
2nd Attempt
Motivated by the neighborhood characterization of openness, define a set $U$ as open if \begin{equation} \forall x \in U \; \; \exists N \in \mathfrak{N}(x) \text{ s.t. } N \subseteq U. \end{equation}
Then, is $\mathfrak{N}(x)$ a neighborhood basis at $x$, given arbitrary $x \in S$?
- For all $N \in \mathfrak{N}(x)$, from our openness definition, $N$ are open as $N \subseteq N$. Then the sets $N \in \mathfrak{N}(x)$ are neighborhoods of $x$. This seems counter-intuitive as neighborhoods need not be open. But here I am.
- Given a neighborhood $K$ of $x$, by definition of a neighborhood, there is an open set $U \subseteq K$ with $x \in U$, then $U$ contains an element from $\mathfrak{N}(x)$, so does $K$.
Hence the set $\mathfrak{N}(x)$ is a neighborhood basis at $x$. Next, we check whether this topology is well-defined or not.
- $\varnothing$ is vacuously open. $S$ is also trivially open.
- Given $U, V$ open, is $U \cap V$ open? Let $x \in U \cap V$, then $\exists N \in \mathfrak{N}(x)$ with $N \subseteq U$ and $\exists M \in \mathfrak{N}(x)$ with $M \subseteq V$. From property (2) given in the problem, $\exists P \subseteq (N \cap M)$, such that $P \subseteq U\cap V$ and $P \in \mathfrak{N}(x)$. Thus intersections are open.
- Unions are trivially open.
I do not know how this topology is uniquely determined.
