I've attempted the following question which involves integration by parts. I've only recently learnt come across this skill, which means there is a very large chance that I'm doing something wrong.
Find $$\int_{-∞}^{∞} Ax^2e^{-x^2/2σ^2} \,dx$$ given that $$\int_{-∞}^{∞} Ae^{-x^2/2σ^2} \,dx =1$$
Using the general form for integration by parts, $$\int_{-∞}^{∞} f(x)g'(x) \,dx=f(x)g(x)-\int_{-∞}^{∞} g(x)f'(x) \,dx$$, I let $f(x)=x^2$, and $g'(x)=Ae^{-x^2/2σ^2}$. Therefore, $f'(x)=2x$ and $g(x)=1$. Substituting these in to the formula, I get $$\int_{-∞}^{∞} Ax^2e^{-x^2/2σ^2} \,dx=x^2-\int_{-∞}^{∞}2x \, dx=x^2-(x^2+c)=-c$$. However, this is incorrect (I know this because I have to submit the answer and the website, which is Isaac Physics, will tell me whether it is correct or not with no explanation). I don't know where I've gone wrong.
  • The middle term in your integration by parts formula is incorrect, it should be the limit of the difference as the endpoints go to infinity. Also, $g(x)\neq 1$. – whpowell96 Apr 03 '24 at 15:46
  • I'm not sure I understand what you mean. As I mentioned, I've only just come across this concept – Developer Apr 03 '24 at 17:50
Integration by parts for this improper integral reads $$ \int_{-\infty}^\infty f(x)g'(x)~dx = \lim_{b\to\infty}\lim_{a\to-\infty}f(b)g(b)-f(a)g(a) - \int_{-\infty}^\infty f'(x)g(x)~dx. $$ The middle term corresponds to the limit as the endpoints go to $\pm\infty$ of the difference $f(b)g(b)-f(a)g(a)$. The integral you start with basically tells you that $\lim_{b\to\infty}\lim_{a\to-\infty} g(b)-g(a) = 1$. If you apply integration by parts with the choices of $f$ and $g$ you started with, the middle term reads $$ \lim_{b\to\infty}\lim_{a\to-\infty}b^2g(b) - a^2g(a), $$ which does not exist. However, if you choose $f(x) = x$ and $g'(x) = Axe^{-x^2/2\sigma^2}$, you will get limits that exist and can proceed as in this answer.
whpowell96
  • 7,849
  • This answer is unclear, and he can't proceed "as in the answer" as you claim. What is $g(x)$ ? This is why it is not clear. The antiderivative of $g'(x)$ does not exist. – Matteo Bulgarelli Dec 17 '24 at 10:18
