There is a longer integral for which integration by parts $\displaystyle\int udv=uv-\int vdu$ was attempted as it came across in research:
$$ \frac i{2\pi}\int_0^{2\pi}\underbrace{\ln\left(1+\frac{e^{-i t}+1}a\ln\left(1-\frac1be^{\frac{e^{it}+1}a}\right)\right)}_u \;d\bigg[\underbrace{\ln\left(e^\frac{e^{it}+1}c-b\right)}_v\bigg] \tag{0} $$
as it has the below problem, but here is a simpler one to better get the point across
$$ \frac1{2\pi}\int_0^{2\pi} \ln(e^{it}+a)\; d\left[\ln\left(e^{e^{it}}-2\right)\right] \tag{1} $$
Integrating $(1)$ by parts should give:
$$\frac1{2\pi}\int_0^{2\pi}\ln(e^{it}+a) \;d\left[\ln\left(e^{e^{it}}-2\right)\right] \\ = \underbrace{\left[\ln(e^{it}+a)\ln\left(e^{e^{it}}-2\right)\middle]\right|_0^{2\pi}}_\text{should equal zero when plugging in directly}-\frac1{2\pi}\int_0^{2\pi}\ln\left(e^{e^{it}}-2\right) \;d\left[\ln(e^{it}+a)\right] \ . \tag2 $$
Directly substituting, we should get $\left[\ln(e^{it}+a)\ln\left(e^{e^{it}}-2\right)\middle]\right|_0^{2\pi} =0$. Checking numerically shows $(2)$ to be false.
However, instead, we numerically get $\ln(a-1)i$ instead of $0$:
$$ \frac1{2\pi}\int_0^{2\pi}\ln(e^{it}+a) \;d\left[\ln\left(e^{e^{it}}-2\right)\right] \\ =\ln(a-1)i -\frac1{2\pi}\int_0^{2\pi}\ln\left(e^{e^{it}}-2\right) d\left[\ln(e^{it}+a)\right] \tag{3} \ . $$
What is the correct way to find the extra $[uv]|_a^b$ term, like $\ln(a-1)i$ here?
dan_fulea
  • 37,952
Тyma Gaidash
  • 13,576
  • Here (2) looks right. In which text book was (3) given ? What was that numerical calculation ? – Prem Feb 28 '24 at 04:18
  • BTW , (2) & (3) long & could be shortened with $I=\cdots$ in (1) & using that $I$ in (2) & (3) – Prem Feb 28 '24 at 04:20
    The issue might be because $\ln$ is multivalued on $\mathbb{C}$? Which branch of $\ln$ you are choosing presumably affects this. Especially when $|a| < 1$, you would be looping around $0$, so the boundary term is definitely not $0$. – David Gao Feb 28 '24 at 04:27
    Even if $|a| > 1$, if the branch cut of $\ln$ intersects with the circle you’re integrating over, this is still an issue. – David Gao Feb 28 '24 at 04:34
  • [[A]] I am not getting what the OP question is about ? [[B]] Who is claiming that (3) is wrong , while (2) is right ? [[C]] Which text book is claiming that (2) is wrong , while (3) is right ? [[D]] Details are missing making it unanswerable ! – Prem Mar 04 '24 at 07:18
  • @Prem [[A]] The integration by parts $[uv]|_a^b$ term is incorrect when directly substituting, so the question asks how one would correctly evaluate it . [[B]] The question actually claims $(3)$ is right while $(2)$ is wrong. [[C]] It is not a textbook, but rather numerical verification and $(1)$ is a simpler integral than $(0)$ to get the point of the question across [[D]] The question has been edited for such readers, so please review it. Does this help? – Тyma Gaidash Mar 04 '24 at 13:43
  • $\ln(e^{e^{it}}-2)$ should fail to be continuous, let alone differentiable, on the entirety of $[0,2\pi]$ so writing "$d$" of it, and using it in integration by parts, wouldn't make sense – FShrike May 01 '24 at 17:08
  • @FShrike From a plot, the imaginary part of $\ln(e^{e^{it}}-2)$ is discontinuous, at $t=\pi$. However, $(3)$ does give a result that likely uses integration by parts. – Тyma Gaidash May 01 '24 at 17:13
  • It seems that one must take break up the integral/take one sided limits for integral bounds to get the missing term. – Тyma Gaidash May 06 '24 at 19:36
According to WolframAlpha, we get $$\lim_{t\to\color{red}{{\pi}^-}}\ln\left(e^{e^{it}}-2\right)=i\pi-1 +\ln(2e-1)$$ and $$\lim_{t\to\color{red}{{\pi}^+}}\ln\left(e^{e^{it}}-2\right)=-i\pi-1+\ln(2e-1)$$
So, if I'm not mistaken, these should give us $(3)$ as follows :
$$\begin{align}&\frac1{2\pi}\int_0^{2\pi}\ln(e^{it}+a) \;d\left[\ln\left(e^{e^{it}}-2\right)\right] \\\\&=\lim_{c_1\to{\pi}^-}\frac1{2\pi}\int_0^{c_1}\ln(e^{it}+a) \;d\left[\ln\left(e^{e^{it}}-2\right)\right]+\frac1{2\pi}\lim_{c_2\to{\pi}^+}\int_{c_2}^{2\pi}\ln(e^{it}+a) \;d\left[\ln\left(e^{e^{it}}-2\right)\right] \\\\&=\lim_{c_1\to {\pi}^-}\bigg(\frac1{2\pi}\left[\ln(e^{it}+a)\ln\left(e^{e^{it}}-2\right)\middle]\right|_0^{c_1}-\frac1{2\pi}\int_0^{c_1}\ln\left(e^{e^{it}}-2\right) \;d\left[\ln(e^{it}+a)\right]\bigg)+\lim_{c_2\to{\pi}^+}\bigg(\frac1{2\pi}\left[\ln(e^{it}+a)\ln\left(e^{e^{it}}-2\right)\middle]\right|_{c_2}^{2\pi}-\frac1{2\pi}\int_{c_2}^{2\pi}\ln\left(e^{e^{it}}-2\right) \;d\left[\ln(e^{it}+a)\right]\bigg) \\\\&=\frac1{2\pi}\bigg(\ln(a-1)\times\bigg(i\pi-1+\ln(2e-1)\bigg)-\ln(a+1)\ln(e-2)\bigg)+\frac1{2\pi}\bigg(\ln(a+1)\ln(e-2)-\ln(a-1)\times \bigg(-i\pi-1+\ln(2e-1)\bigg)\bigg)-\frac1{2\pi}\int_0^{2\pi}\ln\left(e^{e^{it}}-2\right) d\left[\ln(e^{it}+a)\right] \\\\&=\ln(a-1)i -\frac1{2\pi}\int_0^{2\pi}\ln\left(e^{e^{it}}-2\right) d\left[\ln(e^{it}+a)\right]\end{align}$$
mathlove
  • 151,597
  • The $\lim\limits_{c_1\to{\pi}^-}\frac1{2\pi}\int_0^{c_1}\ln(e^{it}+a) ;d\left[\ln\left(e^{e^{it}}-2\right)\right]+\frac1{2\pi}\lim\limits_{c_2\to{\pi}^+}\int_{c_2}^{2\pi}\ln(e^{it}+a) ;d\left[\ln\left(e^{e^{it}}-2\right)\right]$ is almost like a Cauchy principal value – Тyma Gaidash May 06 '24 at 15:12
Issue :
When we write
$$ \frac1{2\pi}\int_0^{2\pi} x\ln(e^{it}+a)\; dx \tag{X} $$ we are saying that the limits are for $x$ (it is not for $a$ , not for $t$)
Likewise , when we write
$$ \frac1{2\pi}\int_0^{2\pi} \ln(e^{it}+a)\; d\left[\ln\left(e^{e^{it}}-2\right)\right] \tag{Y} $$ we are telling Wolfram that the limits are for $\left[\ln\left(e^{e^{it}}-2\right)\right]$ (it is not for $a$ , not for $t$)
Hence we have given the limits to Wolfram :
$\left[\ln\left(e^{e^{it}}-2\right)\right]=0$
$\left[\ln\left(e^{e^{it}}-2\right)\right]=2\pi$
Over-all , the limits which will Wolfram use for $t$ are :
$t=\ln\ln3/i$
$t=\ln\ln[e^{2\pi}+2]/i$
This is not a closed curve.
When we plug that into (2) , naturally , we will not get $0$ where we might want it.
ADDENDUM :
When we Integrate By Parts to get (3) with the new $d[[X]]$ term involving $\left[\ln\left(e^{e^{it}}+a\right)\right]$ , we have to handle the limits correctly & consistently for the "change of variable" there.
When we make the limit changes through-out , the extra term should work out to what Wolfram gave.
Now , the limits Wolfram will see are :
$\left[\ln\left(e^{e^{it}}+a\right)\right]=0$
$\left[\ln\left(e^{e^{it}}+a\right)\right]=2\pi$
Hence , the limits Wolfram will use are :
$t=\ln\ln(1-a)/i$
$t=\ln\ln(e^{2\pi}+a)/i$
SUMMARY :
The Crux is that manually checking gave a $0$ which is wrong because the limits were wrong.
Essentially , the manual work is involving 2 unrelated Integrals.
Difference between those 2 Integrals is coincidentally $\log(a-1)i$ , which Wolfram correctly calculates.
Prem
  • 14,696
