Definition: Given an integrable function $f$ on $[a,b]$ by a primitive of $f$ is meant any function that differs from the function $$F(x):=\int_a^x f$$ by a constant.
Definition: A function $g: [a, b] → R$ is called a step function if there exists a partition $(t_0, t_1, t_2,..., t_m)$ of $[a, b]$, and numbers $(c_0, c_1, c_2, ..., c_m)$, such that $g(x) = c$ for $t_j< x <t_{j+1}$, $j = 0,1,2,..., m - 1.$ In other words g is constant on each open interval $(t_{j} ,t_{j+1})$.
exercise:
There is very general version of the rule for integration by parts that does not rely on derivatives at all.
Its proof is based on the approximation of integrable functions in the mean by step functions. Let $f$ and $g$ be the integrable on an interval $[a,b]$. Let $F$ be a primitive of $f$ and $G$ a primitive of $g$ then $$\int_a^bFg=F(b)G(b)-F(a)G(a)-\int_a^bfG$$ (a) prove the formula in the case that $f$ and $g$ are step functions.
(b) prove the formula in the case that $f$ and $g$ are integrable functions.
Hint. Approximate $f$ and $g$ in the mean by step functions.
My approach:
First I decided think about $f$ and $g$ as constant functions. And define $$G(x):=\int_a^x g$$ and $$F(x):=\int_a^x f$$ In this case it is easy to check that $$\int_a^b Fg +\int_a^b Gf=F(b)G(b)$$ $$g\int_a^b F+f\int_a^b G=F(b)G(b)$$ $$g\int_a^b \int_a^x f+f\int_a^b \int_a^x g=F(b)G(b)$$ Then for step functions we can divide the interval $[a,b]$ to the partition so that in each subinterval the given functions to be constant. And deal with these separeted subintervals as in the previous case. But couldn't deal with it in matematically rigorous way
    This is an immediate corollary of the usual integration by parts formula. You just need a sufficiently general version of the fundamental theorem of calculus, and that’s where the MVT comes into play. – peek-a-boo Nov 05 '23 at 18:20
    Also the derivative of a differentiable function cannot have a jump discontinuity, so trying to prove the claim for step functions first seems weird. Unless of course the author is adopting a non-standard definition for a primitive in this context. – peek-a-boo Nov 05 '23 at 18:23
    I think it might not have been as clear in the original post but now it appears the purpose of the problem is to prove this directly from basic properties of integration before the fundamental theorem of calculus is established. – M W Nov 19 '23 at 03:30
First, one reduction is not strictly necessary, but will simplify what comes next: we observe that if the integration by parts formula holds for a single primitive $F$ of $f$, then it holds for every primitive, since if $\hat{F}=F+C$, then \begin{align*} \int_a^b\hat{F}g &= \int_a^bFg+C\int_a^bg=\left(F(b)G(b)-F(a)G(a)-\int_a^bfG\right) +C(G(b)-G(a))\\ &= \hat{F}(b)G(b)-\hat{F}(a)G(a)-\int_a^bfG, \end{align*} and we may reason similarly for $G$.
Therefore we proceed as you have, assuming $f$ and $g$ are constant on $(a,b)$, say $f\equiv C_f$ and $g\equiv C_g$. By the preceding remark we may without loss of generality assume $F(x)=\int_a^xf= C_f(x-a)$, $G(x)=\int_a^x g=C_g(x-a)$. Then
$$\int_a^bF=C_f\frac{(b-a)^2}{2},$$ $$\int_a^bG=C_g\frac{(b-a)^2}{2},$$ whereby we obtain \begin{align*} \int_a^bFg+\int_a^b fG &=C_gC_f\frac{(b-a)^2}{2} + C_fC_g\frac{(b-a)^2}{2}\\ &=C_fC_g(b-a)^2 = F(b)G(b)\\ &= F(b)G(b)-F(a)G(a). \end{align*}
Next, if $f$ and $g$ are step functions, then subdivide $[a,b]$ into $a=t_0<\dots<t_n=b$ so that $f$ and $g$ are constant on each $(t_i,t_{i+1})$, $0\leq i<n$.
From the preceding result we have \begin{align*} \int_a^bFg+\int_a^b fG &= \sum_{i=0}^{n-1}\left( \int_{t_i}^{t_{i+1}} Fg + \int_{t_i}^{t_{i+1}}fG\right)\\ &= \sum_{i=0}^{n-1} \left(F(t_{i+1})G(t_{i+1})-F(t_i)G(t_i)\right) =F(b)G(b)-F(a)G(a), \end{align*} so the theorem is proved for step functions.
Finally, we extend the result to the general case by approximation in the mean. In what follows, we will use that the absolute value of an integrable function is integrable, and that the product of Riemann integrable functions is integrable.
Now if $f$ is a general (Riemann) integrable function, then let $f_i$ be a sequence of step functions approximating $f$ in the mean, i.e., $\int_a^b |f_i-f|\to 0$. Note then that the primitives $F_i(x):=\int_a^xf_i$ converge uniformly to $F(x):=\int_a^x f$, so we have
$$\int_a^b|F_i-F|\cdot|g|\leq \left(\sup_{[a,b]}|F_i-F|\right) \int_a^b |g|\to 0 \implies \lim_{i\to\infty}\int_a^bF_ig=\int_a^b Fg,$$
and moreover, since $G$ is continuous (hence bounded on $[a,b]$), we have $$\int_a^b |f_i-f|\cdot|G|\leq \left(\sup_{[a,b]}|G|\right)\int_a^b|f_i-f|\to 0 \implies \lim_{i\to\infty}\int_a^b f_i G=\int_a^b fG.$$ Therefore \begin{align*} \int_a^b Fg +\int_a^b fG &=\lim_{i\to\infty} \left(\int_a^b F_ig +\int_a^b f_iG\right)\\ &=\lim_{i\to\infty} \left(F_i(b)G(b)-F_i(a)G(a)\right)=F(b)G(b)-F(a)G(a), \end{align*} so the result holds for an arbitrary integrable $f$ and step function $g$, and the same argument extends the result to arbitrary integrable $g$.
Remark
One might protest that we cheated by assuming that when $F(x)=C_f(x-a)$, then $\int_a^b F = C_f\frac{(b-a)^2}{2}$. After all, this is often demonstrated using differentiation and the fundamental theorem of calculus, which we have arguably foresworn in this problem.
However, using the fact that continuous functions are Riemann integrable, one can also establish this result directly by partitioning an interval $[a,b]$ into $n$ subintervals of length $\frac{b-a}{n}$, and estimating
\begin{align*} \sum_{i=1}^n (t_i-t_{i-1})F(t_i) &= \sum_{i=1}^{n} \frac{(b-a)}{n}\cdot C_f\left(a+\frac{i}{n}(b-a)-a\right)\\ &=C_f\frac{(b-a)}{n}\cdot\left(\frac{n(n+1)}{2n}(b-a)\right)\\ &= C_f\left(\frac{n+1}{n}\right)\frac{(b-a)^2}{2}\to C_f\frac{(b-a)^2}{2}. \end{align*}
M W
  • 10,329
