Given a symmetric positive definite matrix $Q$, $$ \max_{\| x \| = 1} x^t Q x \tag{P} $$
Solving the problem I made the following:
First I see that $\|x\| = 1$ is equivalent to $\|x\|^2=1$, so I replace it because it easier to use it.
Then I construct the lagrange function $L(x,\lambda) = x^tQx +\lambda(\|x\|^2 -1)$
I impose the gradient = 0:
$0=\nabla L(x,\lambda)=2Qx+2\lambda x = 2(Q+\lambda I)x$
So:
$Qx = -\lambda x$
So $-\lambda$ should be an eigenvalue of Q and then $-\lambda>0$
Even more if we are looking for the maximum taking
$-\lambda^* =$ max{μ_i eigenvalues}
And getting $x^*$ as any eigenvector of $-\lambda^*$ with $\|x^*\|^2=1$
We have that $(x^*)^tQx = -\lambda^*\|x\|^2 = -\lambda^*$ and that is maximum.
Is it the solution?
