Let $A=\{x^2\frac{f(x)}{g(x)}:\;f(x)\in\mathbb{R}[x],\,g(x)\in\mathbb{R}[x],\,g(0)\neq0\}$.
Note that for all $r_1,r_2\in R$ you have $r_1 r_2\in A$.
Note also that for any $p(x),q(x)\in\mathbb{R}[x]$ such that neither $p(x)$ nor $q(x)$ has $x$ as a factor, we have that $A\subseteq \big<x\frac{p(x)}{q(x)}\big>$. For such a choice of $p(x)$ and $q(x)$, note that $\big<x\frac{p(x)}{q(x)}\big>-A=\{nx\frac{p(x)}{q(x)}:n\text{ is a non-zero integer}\}$.
Now let $I$ be a proper ideal, i.e. $I\neq0$ and $I\neq R$. We are going to prove that $I$ is not maximal.
Case one: $I\subseteq A$.
For this case, we need only prove that $A$ is not maximal. Just observe that $\big<A,x\big>-A=\{nx:n\text{ is a non-zero integer}\}\neq R-A$. Therefore, $A$ is not maximal.
Case two: $I\not\subseteq A$.
That means that there exists an element of $I$ that is not in $A$. Such an element must be of the form $x\frac{p(x)}{q(x)}$, where neither $p(x)$ nor $q(x)$ has $x$ as a factor. We immediately have $A\subseteq \big<x\frac{p(x)}{q(x)}\big>\subseteq I$. But since $I\neq R$, there exist $r(x),t(x)$ such that neither $r(x)$ nor $t(x)$ has $x$ has a factor and such that $x\frac{r(x)}{t(x)}\notin I$.
Now, the key question is this. Under what conditions is it the case that $cx\frac{r(x)}{t(x)}\in\big<x\frac{r(x)}{t(x)}\big>+I$, where $c$ ranges over the rational numbers?
If for a particular $c$ we have $cx\frac{r(x)}{t(x)}\in\big<x\frac{r(x)}{t(x)}\big>+I$, we can let $cx\frac{r(x)}{t(x)}=\zeta+\beta$, where $\alpha\in\big<x\frac{r(x)}{t(x)}\big>$ and $\beta\in I$. We can write $\zeta=zx\frac{r(x)}{t(x)}+a$, where $z$ is an integer and $a\in A$. Since $A\subseteq I$, we have $(c-z)x\frac{r(x)}{t(x)}=a+\beta\in I$.
We can conclude that the set of rational values $c$ such that $cx\frac{r(x)}{t(x)}\in\big<x\frac{r(x)}{t(x)}\big>+I$ is precisely the set $\mathbb{Z}+Q$ viewed as an additive subgroup of $\mathbb{Q}$, where $Q=\{f\in\mathbb{Q}:\;fx\frac{r(x)}{t(x)}\in I\}$. Recall that $x\frac{r(x)}{t(x)}\notin I$, so of course $1$ is not an element of $Q$.
Now, look at the following link
$(\mathbb{Q},+)$ has no maximal subgroups
whence it follows that $\mathbb{Z}+Q$ cannot be all of $\mathbb{Q}$.
There therefore exists a rational number $c_0$ such that $c_0 x\frac{r(x)}{t(x)}\notin\big<x\frac{r(x)}{t(x)}\big>+I$.
So $I$ is not maximal.
