Let $A$ be an abelian group and let $R$ be a ring. Is it true that there exists a bijective correspondence between the left $R$-module structures on $A$ and the right $R$-module structures on $A$?
I think this should be true, based on the fact that a left $R$-module is a right $R^{\operatorname{op}}$-module. But this alone is not enough to prove the statement, it only changes the problem from finding a bijection between left and right $R$-module structures to finding a bijection between right and left $R^{\operatorname{op}}$-module structures. Also, I have found from here and here that $\begin{pmatrix}\mathbb{Q}&\mathbb{Q}\\0&0\end{pmatrix}$ has a different number of left and right ideals, but this doesn't seem enough to prove that the statement is false.
In conclusion, I'm confused. Any help is appreciated.
Asked
Active
Viewed 136 times
commie trivial
- 1,007
Left $R$-module structures on $A$ are in bijection with ring homomorphisms $R\to End(A)$ and right $R$-module structures on $A$ are in bijection with ring homomorphisms $R^{op}\to End(A)$, or, equivalently, $R\to End(A)^{op}$. Thus it suffices to provide an isomorphism $End(A)\to End(A)^{op}$. – Kenta S Oct 16 '22 at 03:54
I believe this fails for something like $A=\mathbb Z\times\mathbb Z/2$, where $End(A)=\begin{pmatrix}\mathbb Z&0\\mathbb Z/2&\mathbb Z\end{pmatrix}$ – Kenta S Oct 16 '22 at 04:00
Thank you, this seems useful. Could you help me prove how is $\operatorname{End}(A)$ not isomorphic to its opposite ring? I don't understand how the multiplication works here. How can we multiply an element of $\mathbb{Z}$ with an element of $\mathbb{Z}/2$ when we perform matrix multiplication? – commie trivial Oct 17 '22 at 12:50
