Following the advice given in this question, I have started to study Group Theory from the very basics. My reference text is Abstract Algebra by Dummit and Foote. While going through the exercises (page 24) I found one problem which required more effort than others:
Assume $G = \{1, a, b, c\}$ is a group of order $4$ with identity $1$. Also assume that $G$ has no elements of order $4$. Use the cancellation laws to show that there is a unique group table for $G$. Deduce that $G$ is abelian.
I proceeded with solution as follows. Since $G$ is of even order there must be at least one element of order $2$ (this statement itself was one of the problems in the exercises and is easy to handle). From the wording of the question it seems that none of the elements $a, b, c$ is singled out with specific properties and hence $a, b, c$ must behave in exactly the same manner. Hence each of them is of order $2$. Thus $a^{2} = b^{2} = c^{2} = 1$.
Next I analyze product $ab$. Clearly it can't be $a$ (as $b$ is non-identity), or $b$ (as $a$ is non-identity) or $1$ (because $ab = 1 = aa$ implies $b = a$). Hence $ab = c$ and similarly $ba = c$. By the similar nature of all elements $a, b, c$ it follows that $bc = cb = a$ and $ca = ac = b$. Thus the operation of the group is defined properly for all elements and clearly it is abelian.
I think my solution is OK, but I am not sure. Note that I have not used the fact that $G$ has no elements of order $4$. Please let me know :
1) if my solution is correct. If not then point out the flaws.
2) if there is any better / shorter solution. If so provide hints and not solution.
The question may sound too easy / simple but I request to treat me like a beginner who has never heard of Group Theory and is reading fresh from the reference text I mentioned. Thanks in advance for your inputs.
EDIT: Thinking further about this problem I wondered what would happen if an element of order $4$ was allowed in $G$. In that case I think that the group has to be isomorphic to the group $G_{1} = \{1, 2, 3, 4\}$ with modulo $5$ multiplication as the group operation. The argument is as follows. Suppose $a$ is of order $4$ and let $b$ be its inverse then $b$ is also of order $4$. Now $c$ has to be its own inverse so that $c^{2} = 1$. Again $a^{2} \neq 1$ (as $ab = 1$), $a^{2} \neq a$ (as $a \neq 1$), $a^{2} \neq b$ (as it would mean $b^{2} = 1$ and thus $b$ would be of order $2$). Hence $a^{2} = c$ and similarly $b^{2} = c$. Next we can see that $ac \neq a$, $ac \neq c$, $ac \neq 1$ (as $ab = 1$) so that $ac = b$. Similarly $ca = b$, $bc = a$, $cb = a$. Also it is clear that this group turns out to be cyclic with both $a$ as well as $b$ as generators. And it also follows that there are the only two ($G$ in original question and $G$ in new variation) groups of order $4$ upto isomorphism. I hope I have learnt something from the answers given for the original question and this solution is correct. Please let me know if there is any problem with this reasoning.
